Damn, he was right!
Damn, he was right!
I had an mot advisory back in February as there was a sign of cracking around a driver's seat mount on the 2.0. Finally got around to having a look. Another little job to do!
Re: Damn, he was right!
They always like to test us :lol:
Time to start that diet! :xd:
Is that just stress or is there some corrosion on the other side too? Something else to worry about.
What would be the cause of a crack like that?
Just weakening of the metal over time?
Bug wrote: Thu Jul 15, 2021 8:04 am Time to start that diet! :xd:
Mot failure due to middle age spread 🤣
Andrew 2.8i wrote: Thu Jul 15, 2021 7:03 pm What would be the cause of a crack like that?
I would think so Andrew, it's gone along the edge of the reinforcing plate underneath. Maybe need to slow a bit more on the corners😉
stevemarl wrote: Thu Jul 15, 2021 8:16 am Is that just stress or is there some corrosion on the other side too? Something else to worry about.
Looks OK underneath Steve. I'll clean it up to make sure but looks like a stress crack to me.
What's your plan with that Peter, fill the crack with an eventual line of weld? Nice straightforward fix if that will do it.
Caprigear
Post by Caprigear »
That's quite a common failure point. We see it on most of our builds.
STEVEW
Car(s): Ford Capri 2.3S
Project
Post by STEVEW »
Hi steve,
I believe the problem is both fatigue and a little corrosion.
I had a similar problem.
Like you I cleaned and degreased around the cracks after which my son welded them. The welded joints were treated with rust inhibitor.
Plates (x4) were made up and welded on from above.
The finished areas were then sprayed with zinc.
They are pretty flimsy though . Silly thing here is that that sort of mount would pass wof (mot ) on a factory car .... but would be rejected on a scratch build or heavily modified car , you would have to fit 4mm plate of a minimum area ( not sure how big )
mjcapri
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
Post by mjcapri »
Peter-S wrote: Thu Jul 15, 2021 7:50 pm
Clean the crack out with a Dremel or similar Peter and then drill a hole at either end of the crack to “terminate” it. Fill with weld (I’d just MIG it) but you’ll need to be careful of getting too much heat into it. Ideally use a heat sink and be careful of welding too long a run at once. 8-)
mjcapri wrote: Sat Jul 17, 2021 8:00 am
Thanks Mark. I've been using a dremel type thing to clean it. I'm confident I can drill the holes that just leaves the other bit! 😁
Peter,
I`ve been trying to work out which mounting point that is, I`m thinking rear but is it left or right?
stevemarl wrote: Sat Jul 17, 2021 11:17 pm Peter,
Yes Steve, rear of driver's seat next to the tunnel
Peter-S wrote: Sun Jul 18, 2021 8:22 am rear of driver's seat next to the tunnel
Thanks!
I'm going to put this in the car when I'm done😄
Peter-S wrote: Sun Jul 18, 2021 1:32 pm I'm going to put this in the car when I'm done😄
Just make sure they know you're talking about the car.....😳.......you are aren't you?😁. Ah ha ha ha ,just realised that sticker would be better on my car, yeah , that could be real funny 😆
Mc Tool wrote: Sun Jul 18, 2021 6:47 pm
Hamish, there's days when I'm not really sure :xd:
