Lock down jobs...
Posted: Thu Apr 23, 2020 3:45 pm
Well as we're all locked up in our own homes, I decided to get a few of those fiddly little jobs done, that you just never seem to get to... As you know I just got the dash bulbs all done, So onto new tasks.
So as I have just recently had a new windscreen fitted, this seemed to stop the leak I had of rain water going straight into the passenger footwell. Unfortunately though, when we had some rain a few weeks ago, there it was again, a rather large puddle... Crazy, so I changed the door seals for the CCI ones which I had in the garage for a year or so now, thanks to Nick!!! Cheers buddy, so I got to fitting these and they went straight on no problems, go them cut to the correct size and used the small joiner. However, once fitted it was nearly impossible to shut the doors, I adjusted the strike bar to allow them to close,, but this then made the doors look terrible when closed. Anyway, I left them on thinking they would crush down a bit and stop the leak, but come the next rain fall, the puddle was back so the door seals were removed and the originals put back on. Has anyone else had problems with the CCI door seals?
Anyhow, I then noticed the Window strip was starting to crack, so I thought this could be where the water is coming in, so I got the new seals from CCI and got the one fitted to the passenger door, again not overly impressed with the fit as this is definitely narrower than the original and does not quite meet the window glass at the front, but it looks so much better than the old one and it gave me chance to paint up the trim while this was off...20200419_171901 by jon taylor, on Flickr
Please excuse the state of the car, the next door neighbours are having an extension built so it looks like the Sahara has dumped on the car...20200419_171906 by jon taylor, on Flickr
Anyhow, it leaked again so this now was time to pull out the Glove box and trace back the water marks, as it definitely was not coming from the door area...
20200419_162029 by jon taylor, on Flickr
So I looked up behind and found a rotten grommet for the alarm wires, I thought this was it, but once sealed I put the hose over it and looked inside again and I could see the water literally pouring in. So I had to get my head right in and then spotted 2 holes straight through the top of the bulkhead, looks like the original owner was going to have the alarm mounted there till they realised the bonnet would not close... Doh!!!20200419_162059 by jon taylor, on Flickr
Once I got these sealed up too, the hose pipe came out again and at long last, I have a water tight interior!!! (Well as good as Ford made them anyway!!!) So it was out with all the carpet and sound deadening, got this all dry and back in. Brilliant.... So then it was time to address the hole in the drivers seat bolster, it was quite worn and with me getting in and out it finally gave up the ghost. I do want to get these professionally re-covered eventually, but its just not worth it yet as they are overall, still in great condition. So having seen how easy Mr Brewer makes leather repairs look, I bit the bullet and got a repair kit, you have to push a mesh through the hole and glue this in place with the special leather glue, once this is set you rub down the area, clean it all up and use the special leather filler and slowly build this up allowing drying time between layers. Once this is done you start using the dye, again taking your time, allowing drying time between layers till you're happy, then use the sealer. I've not used the sealer yet, as I'm still adding the dye in small amounts, but I think you'll agree, for a home repair it ain't too bad. It will certainly let the seats live on a bit longer. Unfortunately I did not get a pic before I started, I thought I had, but didn't... Sorry, the hole was approx 6mm X 3mm....
I'm still building up the filler at this point, you can see where the hole was...
20200415_192221 by jon taylor, on Flickr
Now rubbed down a bit and some dye added...
20200416_160332 by jon taylor, on Flickr
More dye being added slowly...20200423_140205 by jon taylor, on Flickr
And just about ready for the sealer now...20200423_140243 by jon taylor, on Flickr
As I say, I'm well chuffed with this result and all for only approx £20 for the repair kit then the CCI dye kit....
Has anyone else being fettling with their Cappa during this lock down... It is just a great time to do these crappy little jobs... Stay safe everyone, all the best for now,
John...
John...
