Sunroof Handle
Sunroof Handle
Bloody things, mine has snapped and I tried my best to cut it back and araldite it back together but obviously no joy there.
Anyone have one for sale please? A few on ebay for £100 was sort of hoping not to pay that much if I'm honest!
Re: Sunroof Handle
Martin might have one.
Even more convinced to keep mine shut now
Re: Sunroof Handle
You would think that with all the makes and models of cars that had wind back sunroofs that there is one out there that would have the same spline fitting as the Fords and that could be bought for a fraction of the cost of a Ford one just to get people out of trouble.
Re: Sunroof Handle
No sorry I am right out. I only got three cars in for breaking all through last year and out of those only two had sunroof handles and they're long gone.
Re: Sunroof Handle
I very much wish this was the case!Paul G wrote: ↑Mon Jun 15, 2020 12:39 pm You would think that with all the makes and models of cars that had wind back sunroofs that there is one out there that would have the same spline fitting as the Fords and that could be bought for a fraction of the cost of a Ford one just to get people out of trouble.
Re: Sunroof Handle
As Martin does not have any Danny I seen this one on ebay mate. You might already be one of the bidders but if not heres the link but already up to £50 and likely to go higher no doubt...
https://www.ebay.co.uk/itm/Ford-Capri-G ... SwsV5e42Cw
Re: Sunroof Handle
Thanks for the link Nick, I was highest bidder on that up to £45 but was loathed to pay any more - think I have just about sorted one for now so thanks for the replies guys!
Re: Sunroof Handle
Yep already up to £62 with 3 days still to go. Will prob end up closer to £100 than £50. Glad you got one sorted mate.
Re: Sunroof Handle
Re: Sunroof Handle
Well after fitting mine yesterday (eventually figured it out!) I have noticed that mine is all over the place and will need to be taken out and sorted properly - won't be using that ever again then!!
Something I didn't know and not sure if anyone else does as I've not seen it mentioned before is that there are apparently two different types of handles...
The one on the left is what I had purchased which doesn't have a notch cut out of it, and I was spending ages in the car wondering why it wouldn't fit in. Luckily I had kept the old base and stump of what was left of my handle which has a notch cut out of it so I took the pin out of the handle and swapped the bases over and got it working.
Just something else to check when you buy a replacement handle!
Re: Sunroof Handle
Glad you got it sorted eventually Danny
I would be really annoyed if I broke mine, as it's not a neccesity to open it really!
Re: Sunroof Handle
Only took me five months to finally pull my finger out and buy one haha
The real lesson here should be "don't you even dare think about opening your sunroof"
Re: Sunroof Handle
I've added that to my account signature so I never forget
Re: Sunroof Handle
Re: Sunroof Handle
This was mentioned a while back in the club magazine. I seem to recall John mentioning that there are three different types of handle.
Re: Sunroof Handle
I never knew that , you learn something every day
Re: Sunroof Handle
D366Y wrote: ↑Thu Jun 18, 2020 9:13 am he one on the left is what I had purchased which doesn't have a notch cut out of it, and I was spending ages in the car wondering why it wouldn't fit in. Luckily I had kept the old base and stump of what was left of my handle which has a notch cut out of it so I took the pin out of the handle and swapped the bases over and got it working.
I`m intrigued by this, when you say it wouldn`t fit, do you mean the handle wouldn`t fit on the splined shaft or that the round plastic trim which is located undernreath, and held by, the handle - wouldn`t fit together? As it looks like the only difference is the cut-out/recessed area the disc locates in, otherwise looks the same.Andrew 2.8i wrote: ↑Thu Jun 18, 2020 4:58 pm This was mentioned a while back in the club magazine. I seem to recall John mentioning that there are three different types of handle.
Also, re. there being 3 types, are these backwards compatible, or do they just need their particular variant trim? Surely the mechanism in the roof is the same in all cars? I mean it`s just a splined shaft with a screw in the end. So any handle `assembly` (ie handle and trim) will fit any car?
Re: Sunroof Handle
As you quite rightly pointed out, the mechanism in the roof is the same for all cars.stevemarl wrote: ↑Fri Jun 19, 2020 9:10 am Also, re. there being 3 types, are these backwards compatible, or do they just need their particular variant trim? Surely the mechanism in the roof is the same in all cars? I mean it`s just a splined shaft with a screw in the end. So any handle `assembly` (ie handle and trim) will fit any car?
As far as I'm aware, the round piece of trim is slightly different for the different variants. So, yes, any handle with it's correct trim should fit any sunroof mechanism.
