Bumper Bolts
Bumper Bolts
Anyone know of a source for the little black bolts which hold the rear bumper to the bracket? Either high street or online.
I'm hoping to just buy standard M8 coach bolts (and paint them black) but all of the shops I've been to, the heads are much bigger than the original ones.
Capri Club sell them, but it's £11 for 4, which I may have to pay, but bolts like this at hardware stores are a few pence each. Thanks.
- Car(s): Fiat Tipo diseasel (daily driver)
Re: Bumper Bolts
That’s what I did, just used coach bolts. The “coach” square part was too big to fit the bumper hole but I filed it down to fit so it held in snug and tightened up. Painted satin black and they look just like the O/E. I had no issue with the bolt head size, it was the same as the O/E ones.
Re: Bumper Bolts
I have been thinking that the square bit may be the wrong size, at least yours were too big and not too small! The round heads on the ones I've seen in the shops are quite a bit bigger than original and would be too noticeable I think, especially by me hehe. I don't expect that you got yours from a Nationwide retailer did you, such as Screwfix, etc?
I could get a pack of ten at Toolstation for just over £1, but I don't know the head size, the Ford ones are only 16mm diameter I think.
https://www.toolstation.com/coach-bolt-nut/p29533
Re: Bumper Bolts
If your going to paint them why not just "reshape" the heads. Im thinkin put the bolt in the drill press (or similar ) get it spinning and then use a magicut file or angle grinder (with flap disc) to reshape the head , bit of emery tape to finish her off (Nicks going to want a set of these ) . Must say if you go for the file make sure it has a proper handle covering the tang and wear gloves .
Re: Bumper Bolts
Aren`t there only 2, at the rear, none at the front?
Re: Bumper Bolts
Even if you put the bolt in the battery drill and hold it to the grinder is sure helps to keep things even and ya dont burn your fingers.
Re: Bumper Bolts
They were from Amazon, I was in the middle of lockdown so I just had them sent to me and it was much cheaper than using the ones from the Capri club. They look just like the ones I took off, but not snapped and rusty. Lick of satin black sorted the silver finish. And finding something the same size is much safer than turning a bolt into a missile combining the double power tool wonderment of 2 several thousand rpm rotating power tools and a rather questionable attempt to having a 10 gram blob of steel accelerated skywards when they inevitably meet in new and exciting ways safety first and all that...
Re: Bumper Bolts
I'm sure if I search on amazon I'll get a gazillion results, please would you be able to direct me to the ones you have. Most head diameters seem to be around 20mm so that's great to find them closer to the original of around 16.
Re: Bumper Bolts
I've been able to get some bolts with the right size heads from one of those budget sell everything type shops, so job's a good 'un.
Re: Bumper Bolts
Stainless (Aisi316 ones) of these would be perfect for modification.pbar wrote: ↑Fri Apr 30, 2021 8:16 pm I have been thinking that the square bit may be the wrong size, at least yours were too big and not too small! The round heads on the ones I've seen in the shops are quite a bit bigger than original and would be too noticeable I think, especially by me hehe. I don't expect that you got yours from a Nationwide retailer did you, such as Screwfix, etc?
Re: Bumper Bolts
That's the Capri Club yes, almost £11 for 4.
- Car(s): 3.0 Ghia
Re: Bumper Bolts
If you don't have the time to tinker & just want to plug & play as it were, not excessively expensive. Picked them up from the club & fitted them on mine when doing the resto.
Jeez that was 5 years ago !!!!
Re: Bumper Bolts
Thats about what Id pay for 1 doz box of Becks or Kingfishers so if it got the job done ,not a bad price .....painted bolts wont ever be cheap
Re: Bumper Bolts
I want to say I have a box with a couple of spares in should anyone need any (don't hold me to it) but if it's of interest let me know and they're yours for the cost of postage provided I can find them!
Re: Bumper Bolts
Oh , so like a government promise then ?
Re: Bumper Bolts
At least I will actually provide if I can rather than just bullshitting you!
Re: Bumper Bolts
I know what you mean tho , I promised a new nla Ducati part ( blinker lens ) to someone , normally I dont let nothing go but Im never going to be able to ride the bike again and he wanted one to help finish off a project rebuild so I pledged it and now cant find it ,had 2 lefties and 2 righties . I used one leftie when I whacked it against the bedroom door frame whilst riding bike ( dont ask....... ) . Wadda ya do ? Tell him tough shit or give him the one off my bike and hope I find the missing one
