Mk1 auto gear selector clips
CapriDriver
Car(s): Mk1 3000E
Post by CapriDriver »
Hi. I have an automatic Mk1 pre-facelift. The part which the PRND21 housing attaches to has 4 fixing holes and these should have clips inserted in them. Mine only has one clip in place - the other three are missing, as can be seen from the attached photos. The holes are size 6mm. Does anyone here know where I can get new clips to match the existing one ?
Re: Mk1 auto gear selector clips
Think you may have a hard time finding the exact clips or whatever you want to call them, but they were the same on all auto capris regardless of the year, and I would imagine can also be found in any other Ford of the period with a C3 box so someone may have some knocking around
Otherwise you will probably need to fashion your own
SCP440
Post by SCP440 »
https://www.scimitarparts.com/product-c ... ission-g6/ Item 12
Well worth ringing to see if they are availble.
Oddly some Reliant stuff seems easier to get that Ford stuff.
I needed a breather hose that is no longer available as a Ford part number but is as a Reliant.
Steve
millerlite
Car(s): 1983 2.8i (project), robin hood kit kit car 2lt pinto,freelander 2 daily driver, kawasaki er6f daily rider
Post by millerlite »
would be able to cut down the tube from a silicon/mastic tube ?
CapriDriver
Car(s): Mk1 3000E
Thanks for the lead, Steve. I'll chase this up with Scimitar Parts.
Cheers, Simon
SCP440 wrote: Tue Sep 19, 2023 4:32 pm https://www.scimitarparts.com/product-c ... ission-g6/ Item 12
Steve
