Clanking noise
- Car(s): Ford Focus titaniumX daily driver.
Ford Capri 2.8i. Superb, dry days only. Kawasaki GPZ 900R. - Location: Suffolk
Clanking noise
Hi all, Hope somone can help with noise coming from my 1986 2.8i. I know noises are difficult to diagnose without actually hearing bur here goes. Metalic clanking type noise coming from the engine. Started after winter hibernation and getting worse. Engine starts and runs and idles perfectly. At low revs when first started the noise is very prominent but raising the revs the noise disappears as though removing slack from a timing chain, but of course no timing chain returning when back at idle. Removed all the belts at the front of engne eliminating all the pully bearings, noise still there. Checked the engine mounts, all good, nothing loose. Noise appears to come from the top of the engine and does not go up and down with revs. Car drive perfectly on the road but the noise is getting worse as even the wife noticed it. Hope someone can give me a push in the right direction Thanks in anticipation...Peter
Re: Clanking noise
As you say, without hearing it a diagnosis is difficult but as you have tried with belts off I would suggest checking the valve gear.Pedro 70 wrote: βFri May 26, 2023 4:04 pm Hi all, Hope somone can help with noise coming from my 1986 2.8i. I know noises are difficult to diagnose without actually hearing bur here goes. Metalic clanking type noise coming from the engine. Started after winter hibernation and getting worse. Engine starts and runs and idles perfectly. At low revs when first started the noise is very prominent but raising the revs the noise disappears as though removing slack from a timing chain, but of course no timing chain returning when back at idle. Removed all the belts at the front of engne eliminating all the pully bearings, noise still there. Checked the engine mounts, all good, nothing loose. Noise appears to come from the top of the engine and does not go up and down with revs. Car drive perfectly on the road but the noise is getting worse as even the wife noticed it. Hope someone can give me a push in the right direction Thanks in anticipation...Peter
Re: Clanking noise
Having suffered many noises over the years I can attest to starting with valves
Otherwise my only other big noise was the bottom end letting go which was unfortunately a much bigger fix
Re: Clanking noise
Thanks guys will delve into the valve area. Will let you know if I have any success.
Re: Clanking noise
Valve area seems fine but further investigation is leading me towards the front of the engine. Could either of the timing wheels work loose and rattle around on the shafts do you think? Not come off therefore allowing the engine to run perfectly. Any thoughts before I start removing the covers. Thanks
Re: Clanking noise
I dunno jack about ford V6's but most of the engines using timing gears leave the factory with the camshaft gear having nylon teeth ( to reduce noise ) and these do tend to disintegrate at some point .........so you might be on to something there.
Mmmm Kwaka 9 , one of the good ones too
Re: Clanking noise
Just a quick update. Timing cover off, great expectation and - nothing wrong in there, all good and tight. Now suspect that the fly wheel maybe the culprit. Not sure but definitely getting worse. Now booked in to a garage next week to let them have a listen when up on ramp.
Re: Clanking noise
Could be a loose or damaged spring on the clutch pressure plate, I have seen this on a couple of cars. One on an MG sounded so bad I thought the big ends were about to come out. Once replaced it sounded like a new engine.
Re: Clanking noise
Think you could be right there. Took it to a recommended garage today and he dismissed any sort of engine fault. Thought it was in the gearbox area. Really loud noise now, getting worse very quickly, and the car runs beautifully!!!!! Any way he has taken it in and hopes to start on it tomorrow or Monday. Thanks for your thoughts.
Re: Clanking noise
I have seen on more than one occasion where flywheel bolts have come undone and fallen out. They make an almighty rattling noise. All my instances of this were on pinto engines in both Cortinas and Capris but it could happen on any make or model.
Re: Clanking noise
Spot on Paul, just got my Capri back from the garage. He said all flywheel bolts were coming undone. No lock tabs on these engines but should have had thread lock on bolts. So much for the restoration company in the M40 area that carried out the complete restoration of my car some 7 years but only 6k miles ago. Iβm absolutely amazed at how noise like this can appear to come from all parts of the engine until things really get bad. Thanks to all that gave me their thoughts with this. Peter.
Re: Clanking noise
Just shows you how saving the few seconds extra it would have taken to do the job properly means it all has to be done again! Can`t help thinking you`re lucky the ;flywheel flailing around didn`t cause serious damage. Moral: If you find someone you can trust stick with them. (then they retire, new ownership... )
Re: Clanking noise
You are so right Memo !
Re: Clanking noise
Sorry NEMO
