Can someone tell me what order to check different parts
Car wouldn't start, changed a few bits still no good, tries to fire
Changed fuel and filter
Tia
2.8
Non starter
Re: Non starter
Previously a runner?
If its trying to start then presumably there is a spark and some fuel getting through. If it has not been used in a while then I would suspect the central plunger in the metering head is stuck but also worth checking the gauze under the larger banjo connection on the warm up regulator isn't blocked.
Re: Non starter
Yes was a runner, started spot on
Have checked wur, have spark
Did mesh with mixture I know I shouldn't have
Thought low on fuel so drained it and fresh ib
Re: Non starter
When the engine is properly cold disconnect the 7th injector at the plenum end, pop it in a jar and crank the engine. Fuel should come through OK. If not then check the fuel pump, you should hear it whirr anyway just turning the ignition one click.
Presumably ignition timing is all properly set.
Re: Non starter
recently had this with a Rover SD1 EFi - it was a blocked fuel filter.
Re: Non starter
Yes got fuel through the 7th injector, take out purple relay atm and put heated screen one in, I can hear pump
- Car(s): Ford Capri Cabaret 1.6,Ford Cortina MK5,1992 Ford Sierra Coupe,1988 Ford Sierra Coupe.Ford Sierra XR4i
Re: Non starter
Did you check for spark?
Re: Non starter
Hmmm... That mixture screw is very sensitive, half a turn either direction will throw your mixtures right off. How far did you turn it and which direction?
What was the few bits you changed?
