Hi all,
I currently have a Weber DGAS 38 with an automatic choke, on a Manual 3.0 Capri. I am looking into getting a brand new carburettor for it. What would be the best one to get (I want to keep it all standard though). Any website links etc?
Onto the automatic choke- I disconnected the automatic choke from the carburettor to fully clean and put back on. I have then put everything back together, attached back to the carb and have gone to start it. The auto choke now leaks water from the bottom. I didn’t experience any leaks before originally taking it off. I’ve double checked that nothing is missing, whilst making sure everything has been put back on correctly?
Any help/suggestions to my queries would be much appreciated!
Many thanks
Carburettor And Automatic Choke Help!
Re: Carburettor And Automatic Choke Help!
I have used Webcon before for new carbs and quality etc. Has been great, not sure they will have exactly what you want but worth a look.
https://www.webcon.co.uk/products/c22-s ... burettors/
In terms of keeping things standard i would ask why bother changing your current one if you want to keep it standard....your current one is standard and presumably working before the leak?
Personally I'd save yourself a few hundred quid and just fix the one you currently have
Danny is right and if you look under carb spares you will see that they sell choke o-rings and gaskets which may well solve your leak.
I have heard a few horror stories re the weber auto choke .......but if you set it up correctly they are blimmin great . You could even get the o ring at a hardware shop . Probly the only real reason to swap carbs would be if the throttle shafts and carb body wear , or corrosion , everything else can be fixed
As Paul suggested, a rebuild may be your best bet. Webcon sell kits for that and covers everything - we rebuilt mine at CRaP last year in a field
Hi all, sorry for the delayed reply. Thank you so much for your help and suggestions, much appreciated! Lucky some strong sealant has solved my leak… for now. I’ll continue to monitor it! Thanks once again!
