Headlight washer relay
T.M.
Post by T.M. »
does anybody know if it's possible to set opreration time of headlight washers? Something inside relay what could be set?
On my Capri it's around 0.5 sec. On right headlight it's ok (on LHD washer tank is on the right side), but left headlight has longer hoses and in 0.5 sec it only starts to squirt. So it starts to squirt and ends immediately.
Thanks.
Tom
T.M.
Re: Headlight washer relay
Post by T.M. »
...or are there any pressure valves in washers, which could be stuck?
Tom
Um , push the button twice ๐Ÿ˜†
T.M.
Post by T.M. »
Great, thanks! :lol:
I had the same idea. It didn't work much...
Tom
SCP440
Post by SCP440 »
The pipe must be empty when you are putting them on. On mine the pipe stays full so as soon as I put them on they spray water. Is there supposed to a valve or do you have an air leak allowing the water to escape? Put some news paper under the car and see if it catches any drips.
T.M.
Post by T.M. »
It didn't look that there is any leak, but I will check it once more. ;)
Tom
T.M. wrote: โ†‘Sun Mar 05, 2023 12:23 pm
Thanks.
Tom
prostrate ๐Ÿ˜†
Mc Tool wrote: โ†‘Tue Mar 07, 2023 1:32 am
Thanks.
Tom
prostrate ๐Ÿ˜†
It's prostate :)
T.M.
Post by T.M. »
It's an old machine. :lol:
nemo
Car(s): none at the moment
Post by nemo »
Bit of overkill but if you`re prepaed to do a bit of wiring, you could replace the relay with something like this for a fiver (???) and give you adjustable time. Set it up then put away under the dash?
https://www.ebay.co.uk/itm/253632542177 ... R7CDgN7aYQ
T.M.
Post by T.M. »
I want my Capri to be as original as possible. So if I want to solve this I will inspect that washer or try another relay or anything else.
But thanks for info about this possibility. ;)
Tom
nemo
Post by nemo »
[/quote]
prostrate ๐Ÿ˜†
[/quote]
It's prostate :)
[/quote]
To be fair that`s a common mistake. Another is Emphysemia
