Does anyone have any tips and tricks for the fuses an be headlight relay at all?
I'm bored of having to clean them up every few months with wet and dry so was going to take them out and clean them up properly with a dremel but wondered if there was anything else I could do or put on them to try and make it last a bit longer??
Tips and tricks
Tips and tricks
Re: Tips and tricks
Slight smear of grease after you have cleaned them up might help Danny.
Re: Tips and tricks
Great stuff thank you Paul
Re: Tips and tricks
The contacts shouldn't need cleaning that often!
You do have that protective rubber cover that protects the electrics underneath the headlight relay, don't you?
Re: Tips and tricks
How about some Vaseline? A smear can work wonders on stuff like this.
Re: Tips and tricks
I do have the rubber cover yes - I always forget which car it is I've done it one last but it feels like I'm doing it all the time (or that it needs it and I can't be bothered and put it off )Andrew 2.8i wrote: ↑Sun Dec 18, 2022 12:45 pm The contacts shouldn't need cleaning that often!
I have heard about vaseline as well, have put some on the battery terminals in the past so will put some of that or some grease on
