Overcooling
Overcooling
..is this actually a thing?
Since the new aluminium radiator, and probably knackered thermostat that will have to wait until after Christmas, my water temperature in these wintred weeks has been way low, and at any kind of speed, so low I have been a bit worried about oil temperature.
I have added the high tech Adjustable Monolithic Fibrous Thermal Regulation Device for now, but just wondering on your thoughts about cooling overefficiency.
Re: Overcooling
A piece of cardboard, I assume?
Re: Overcooling
Long term use with an over cooled engine is not a good idea, condensation in the oil wont evaporate and the ware in the engine will be higher. Engines are designed to run at between 85 and 95c. I think the coldest thermostats you can get are about 75c so in theory that is the coldest the engine will run at.
Re: Overcooling
I have noticed a similar issue with both of mine since fitting CoolEx ally rads - only because the air blowing around is no longer warm
The fans on both are (obviously) broken, (I did fix them both during COVID but both now fucked again and can't be bothered taking it all out again) but they at least used to have warm air coming out before the rads were fitted now they only blow cold air at me all the time.
Having said that, I have noticed that mine gets warm enough to send the temperature gauge up to about 1/2 or 2/3 ish and then it drops down again to probably about 1/3 - I assume this is when the thermostat opens, which would explain why it drops again - so if your thermostat is broken and presumably then not opening, that may be the issue....??
Re: Overcooling
Re: Overcooling
Well, my heater matrix started leaking, slippery feet what what! So I bypassed it.D366Y wrote: ↑Sat Dec 10, 2022 8:13 pm I have noticed a similar issue with both of mine since fitting CoolEx ally rads - only because the air blowing around is no longer warm
Surely mine is stuck open though, mine barely goes over the second line. In this weather doesnt even get there!
Re: Overcooling
Top tips, thanks! I shall keep the cardboard in thenSCP440 wrote: ↑Sat Dec 10, 2022 6:09 pm Long term use with an over cooled engine is not a good idea, condensation in the oil wont evaporate and the ware in the engine will be higher. Engines are designed to run at between 85 and 95c. I think the coldest thermostats you can get are about 75c so in theory that is the coldest the engine will run at.
Re: Overcooling
An easy way to tell would be to run it for a while and then take the rad cap off - if you don't get scalded it's not running warn enough, if you do get scalded and your skin starts peeling then it's fine
Re: Overcooling
Another top tip I'll do that now!
Re: Overcooling
Maybe what you need is something to generate sparks in the engine bay to keep it warm?
Re: Overcooling
I will do that as soon as my burns have healed Martin!
Re: Overcooling
The overcooling's got even worse.
Re: Overcooling
Tell me about it, mine has been doing something similar!
Re: Overcooling
Wow, look at those ice crystals! Beautiful.
Re: Overcooling
Love seeing pics like these, proper cars in proper use. Full credit to you guys
