Hi all, I was wondering if anyone is looking to sell the following parts:
-4 speed 2.8i Recaro interior (with the blue check)
-2.8i round radiator cap (without the sprint at the bottom)
-2.8i radiator fan shroud
-2.8i top water housing
Many thanks
Wanted 2.8i parts
Re: Wanted 2.8i parts
The top water housing is quite hard to get hold of now, as you probably know, they are susceptible to corrosion and cracking.
Are you aware that CCI have commissioned a limited run of repro items?
They aren't cheap but they will last the lifetime of your car, which may not be the case with a 30+ year old secondhand replacement.
https://www.capriclub.co.uk/Alloy_Top_H ... --869.html
Hi Andrew, thanks for your reply. Yeah I have seen that CCI are reproducing these but I wanted to know if there are any second hand or NOS ones out there maybe?
I have 4 alloy top housings available. 2 refurbished and 2 good used
- Car(s): Ford Capri V8 Twin turbo.
W reg black 3ltr S - Location: Melbourne Australia
Have you tried Martin from Caprigear for your requirements?
