Timing belt
- Car(s): drive 73 yellow 1300 facelift with a 2000cc engine
and a 76 V W beetle - Location: Shrule Co Mayo, Ireland
Timing belt
Hi all I have a 1973 mk 1 facelift with a 2,000 block over head cam it has been parked up for the past 8 years and not driven while i am restoring it question is where can i purchase a timing belt is it possible to get one in ford garage any idea where i can purchase one many thanks to members who helped me in the past I live in Ireland Michael
- Car(s): Rat - GONE
Re: Timing belt
There are loads on ebay, would have thought most decent parts shops could get you one as well
Re: Timing belt
Thanks for your help
Re: Timing belt
And ,after being parked up for that long I would remove cam cover and pour a good dollop of engine oil along camshaft before you start turning engine over to prime oil supply
Re: Timing belt
Thanks for your reply and advise did not think of pouring oil over cam.
Re: Timing belt
It will be pretty dry after sitting for so long, and cranking speed is real hard on the cam/follower at the best of times ,and the pinto engine aint particularly robust in that dept anyhow . By the time you have cranked up oil pressure some damage could be done.
