2.9 BOB Cosworth 24v ECU / MAF
80s-new-man
Ford Sierra XR4x4 2.9 1992
Jaguar XJR SC 4.0 2001
Post by 80s-new-man »
Hi there - has anyone got, or experienced having a Capri with such heart transplant? Mines running a 1995 Scorpio Cosworth 24v 2.9. Sometimes she runs really fast at start up or just randomly whether hot or cold - 1500 or 2000 revs. A few times she’ll stall at cold Tickover.
I’m thinking to start with the MAF. I cleaned it but no joy.
I noticed the part number is 91GB-12B579-AA but looking up the part I get 94BB12B579CA for the Scorpio.
Now I have no idea what ecu she’s got but I heard something about that the ECU from the earlier Granada Scorpio is normally fitted.
Is that the case? Would no way the later Scorpio ecu be fitted for some reason?
Alternatively I may be barking up the wrong tree, should I be checking ICSV or air temp sensor diode as well ?
Sierra XR4x4 2.9i 1992
Jaguar XJR 4.0 SC 2001
Jaguar F-Type 3.0S sc 380
[email protected]
Re: 2.9 BOB Cosworth 24v ECU / MAF
Post by [email protected] »
Have you confirmed Coolant temperature sensor values? They play a part in start up enrichment, effectively telling the ECU it needs “choke”. You should be able to find values for it’s output hot/cold to see if it’s responding correctly. Then check the rest of the items you’ve listed, they can all stick an oar in as well :xd:
80s-new-man
Nope I didn’t.. how is that done? I do notice she runs a little colder than I’d have thought.
[email protected]
The Haynes manual for models with that engine should list a resistance value for the coolant sensor both hot and cold. If it’s out of tolerance the ECU (basic as it is on these engines) will substitute values or just respond incorrectly. As there’s very little plug in support (EOBD) for older cars I’d recommend the old Haynes manual on diagnostics which listed sensor types and diagnostic tests to help you check expected values of your system’s components. May help you find the fault.
80s-new-man
Appreciate that! Cheers
