Side window trims
Side window trims
Afternoon all. Quick question. How do the side window trims come off? I want to start stripping it ready for it’s respray and the body shop said I have the option to save myself some beer vouchers and do the strip down of trim. If they’re a royal pain in the lower back area I’ll leave it to the professionals but if not…I’ll have a crack and save a few hundred in labour. Everything else but the spoiler has been off recently anyway so it shouldn’t be too much of a hassle for the rest. Spoiler might be a bit of a mare yet though
Re: Side window trims
The front window trims can be removed quite easily. Get something flat, place it between the trim and the door skin and lever upwards. You'll have to work your way along the trim doing this. The clips that hold the trims in place are rivetted on, should you wish to remove them.
And the curvy rear window trims?
There's a couple of rivets on the B-pillar that will need to be drilled out. The trim is in two parts, the top section is screwed on from inside and the interior trim will have to be removed to do this. The bottom section needs to be levered off in the same was as the door trim.
This description applies to the trim on cars with opening rear windows. I'm not 100% sure, but I think if you have fixed rear windows there is also an additional piece of trim on the B-pillar.
