One of those days.
One of those days.
..so I went out in the Capri to go and pick up some paint. Brimmed it with 100 quids worth of Esso. On the way back, the gearbox is heaving over to the right when under hard acceleration :shock:
So I pull over, check engine and gearbox mounts, bellhousing bolts... everything's as it should be, apart from one bellhousing bolt that goes through that bracket near the clutch cable. Chuckled a spare on anyway but I'm like :headscratch:
So I get in, see if that helped. It didnt, so I resolve to limp home and investigate further.
I go 10 metres and suddenly it's on two cylinders. Open the bonnet and fuel is just gushing out of the trumpets of the first carburettor ๐Ÿ™„
Only got my basic tools on me, so did what any right thinking man would do: called the AA and gone to the nearest pub.
Should have stayed in bed!
Re: One of those days.
AA just left. He couldn't work out what was going on either :headscratch: but after we took the floats out, looked at them, did some more :headscratch: put it back and it just worked again :headscratch: :headscratch:
Regards to the lurching box, do we think gearbox mounting rubber has had it boys?
swap it for a mk111 Zepher .........real quick :xd:
I dont think a gearbox mount would cause the motor/trans to rock ...........broken left side engine mount would . Youd have to get in there with a lever and try and tip the motor over whilst looking to see whats going on :)
Mc Tool wrote: โ†‘Wed Jul 06, 2022 8:19 pm swap it for a mk111 Zepher .........real quick :xd:
It is weird. And yes my man you ARE right there.. the day after looking at another female, the Zephyr, she breaks down in floods of tears. Will jack up the engine tomorrow and see what moves.
I have upset the poor lady :(
Yep, engine mount rubber broken. Other side just about to go too. Only 1 month old from rallydesign :shock:
Crap quality ๐Ÿ™„
Major_Tom wrote: โ†‘Thu Jul 07, 2022 2:32 pm Crap quality ๐Ÿ™„
That has got to be a refund surely?
Will ensure it will be. Apparently a few people haven't been happy with stuff from rallydesign recently. Sad when a company goes down hill like this.
Could be all that torque from that mighty pinto engine๐Ÿ™„๐Ÿ™„๐Ÿคฌ๐Ÿ˜† ........(them 45's wont be helping either.......other than weighing down that side of the engine) .....just ripped er apart ๐Ÿ˜
Do Rally Design source their parts from the same manufacturer as every other supplier though?
Andrew 2.8i wrote: โ†‘Thu Jul 07, 2022 8:21 pm Do Rally Design source their parts from the same manufacturer as every other supplier though?
Not sure, but the mounts I got were supposed to be heavy duty ones. They have a larger diameter than the standard ones and flex a lot less.
Post by Caprigear »
I've stopped using the "new" mountings on my builds. The originals are much better. I have some if you need them.
Thanks Martin, I have a couple of genuine ones on there now from my mate who had used 4 of them for insulators on the legs of his compressor :) he's changed compressors since so had them as spares fortunately.
My mistake - it was Burton Power not rallydesign, sorry about that. I have since seen that Burton sells metal cups that enclose the insulators... for ยฃ40 for the pair :shock:
Seems a little like they fabricated them after realising the bushes were crap, but maybe I'm just being cynical!
Post by Mr B »
Major_Tom wrote: โ†‘Fri Jul 08, 2022 1:07 pm My mistake - it was Burton Power not rallydesign, sorry about that. I have since seen that Burton sells metal cups that enclose the insulators... for ยฃ40 for the pair :shock:
IIRC some Capri models came off the production line with those metal cups, possibly 2.8's or Mk 1 3 litres, I'm not 100% sure but 3 of my Capri's have them fitted and they have been on the cars for years.
Mr B wrote: โ†‘Fri Jul 08, 2022 8:39 pm
Yes it says some Capris had them factory fitted on their website I notice.
