Headlight disassembly
Posted: Fri Jul 01, 2022 11:43 am
by Major_Tom
..hello you fine people. I have found one of my original headlight units, reflector corroded, but the glass has my reg etched into it, as does all the glass on the car, so it seems a shame not to do something with it.
Can the lens be removed and swapped onto a different bowl? What do I need to do so?
Re: Headlight disassembly
Posted: Tue Jul 05, 2022 7:43 pm
by Supercharged Nat
Hey Tom, many years ago i seperated the lens from the reflectors, even heating of the sealant and careful prying / cutting with a thin blade eventually got them apart. A polyurethane sealant/ adhesive should hold them together again ( i think i used a clear silicone sealant) once old sealant is removed.
Posted: Wed Jul 06, 2022 12:56 pm
by Major_Tom
Nice one thanks mate
Posted: Thu Aug 11, 2022 6:21 pm
by Kelvin Pugh
I put mine in the oven for 15 mins then prised off the lens when the sealant was soft.
Posted: Thu Aug 11, 2022 8:09 pm
by SCP440
The sealant that is used is called Butyl Sealant, it is available in strips that can be molded once warmed. The way I have used it in the past is to apply the sealant to one of the parts and put it in an oven at the lowest setting. Leave it in there for 10 to 15 mins and then remove it with an oven glove, assemble the two parts and clamp using some pressure, it only takes 10 mins to go off and once cooled is watertight and the two parts are impossible to seperate unless heat is applied again,
