..so I did my valve clearances this afternoon, jumped in the car for a test run and found that the clock, that has been buggered for a year, has started functioning again.
Also my voltmeter, which has never worked ever since I bought this car 16 years ago, has suddenly begun working. But the horn is now bust
Fo any of your cars have odd habits?
Quirks
Re: Quirks
My indicator on the rear recently stopped working but couldn't for the life of me figure out why
Swapped it with the front one and both worked - not the first time it has done so!
My rev counter also has a habit of occasionally just not working for the first 10seconds of the engine being on, but then suddenly decides to work
Re: Quirks
Might pay to do a dummy practice disconnect the rev counter wire at the coil on roadside. Mine did similar thing , also would die for ½ a second, and take the sparks with it. I didnt know what caused it till the engine died ( halfway up a hill heading out of Nelson at peak traffic ). Turned out the tacho had a intermitant short when something inside got hot and shorted the coil - to earth .
Re: Quirks
That's what I do, always works!
Re: Quirks
Quirks.......
I once mistakenly hit a lever on the side of my steering wheel and two rubber lined "arms" moved across and back on my windscreen.
Re: Quirks
What is this devilry.Fordoholic Nick wrote: ↑Tue Jul 05, 2022 2:22 pm Quirks.......
Re: Quirks
