Hi
Can anyone tell me what the bulb type and wattage is for the ones behind the clock and the tiny one for the heater control.
bulb types
Re: bulb types
Hi Mark,
These are the bulbs for the clock:
https://www.ebay.co.uk/itm/131326618952 ... 108&ff19=0
Re: bulb types
Thanks Andrew, I thought you would have the answer, just been and got a pair from halfords. They also have the tiny bulbs for the heater control light in 1.2W and 2.3W versions, any idea which one.
Re: bulb types
3 watts max for the dash ,otherwise the heat ruins the plastic ,not sure about the heater tho.
I lined the inside of my dash with aluminium tape and fitted led,s. Available in different colours but they are polarity sensitive and the dimmer doesnt work any more
Re: bulb types
Ive just done the same on the dash clocks and fitted standard green bulbs so i can still use the dimmer, lined with silver tape after reading yours and Johns write ups. I have also changed the heater motor and matrix so this is when I realised that there is a bulb in the back of the heater controls which has blown so need to change it.
Re: bulb types
Sorry Mark, I can't remember off hand and there's no mention of that bulb in the Haynes manual. The clock ones are 1.2W, I would guess that the heater panel one would be the same?
Re: bulb types
I think the heater bulb might be a T5 capless, although I'm not 100%
https://www.ebay.co.uk/itm/133778414435 ... SwTnBgt6H2
