Sunroof grumbles (1986 2.8 Injection)
CraigA
Car(s): Feb 1987 2.8 Injection Special. Waxoyled and garaged from new - 99% original survivor
53,000 - consecutive MOT's
Being one of the last it is in Crystal Blue over Silver
Unpainted, unrestored - and I just love it!
Post by CraigA »
My sunroof didn't sound happy when moving it back and forwards; so as per YouTube videos I hoovered out the tracks, made sure the drains were clear, cleaned off all the old grease with a solvent and used a light machine oil to re-lubricate.
The sunroof now goes back fine, but I have to force it to tilt. Obviously my concern is not wanting to damage the mechanism.
Any suggestions would be welcome
Craig
Re: Sunroof grumbles (1986 2.8 Injection)
When you say 'force it to tilt' what bit are you forcing? I guess you mean the handle/winder? Or do you mean you are forcing the switch to change between them?
CraigA
Post by CraigA »
Thank you for the reply
But no, the switch flips smoothly. It's the handle/winder the I have to force?
CraigA wrote: Tue May 24, 2022 9:41 am But no, the switch flips smoothly. It's the handle/winder the I have to force?
I would stop using he sunroof until the issue is fixed. The handles have been known to snap and a replacement could cost you an arm and a leg.
As an indication, there's only one decent one on Ebay at the moment and it's £95.
Andrew 2.8i wrote: Tue May 24, 2022 5:09 pm
I can vouch for that - it's more annoying to have a broken handle than not use it, and definitely worth saving!
The fact that it sticks when trying to tilt is a weird one considering there should be little to no resistance... If everything is greased and cable isn't old then I am stumped beyond that I'm afraid
I keep thinking I'll fabricate a mild steel shaped 'sleeve' to neatly slip onto the orginal handle to reinforce it. Could also be used to aid repair of broken ones also as I assume they usually snap along the length of the handle itself.
Mine snapped right where the handle things out to join to the mechanism as the metal goes from being thick and study to only a few mm thick
CraigA
Post by CraigA »
All noted guys, your replies are really appreciated.
D366Y wrote: Wed May 25, 2022 9:05 am the metal goes from being thick and study to only a few mm thick
You can fill that thin 'void' with chemical metal/filler, or similar to strengthen it. There is a tab on the other part which locates in that void but doesn't appear to do anything, so that could be ground/drilled off.
The handle would be similar strength on the full length then, with no weak spot.
pbar wrote: Mon May 30, 2022 9:33 am
I think I kept mine so will definitely have to give this a try! Thanks Paul.
