I have been investigating the reason that the drivers seat on my Capri Ghia appears loose even though the bolts are tight. The reason is the rail that does not have the adjuster has no rollers or bearings just the remains. I have had a look on Ebay and all the usual suppliers but nobody seems to have anything listed.
Does anyone know where I can get a seat rail ?
I have looked at the universal route and they all appear to be too short as the distance between the mounting holes on mine is 360mm and the ones I have found are at least 100mm shorter, I could modify if needed but I would prefer to find the correct part if possible.
Seat rail
Re: Seat rail
Thanks, its the one with out the lever, I will give you a ring later if thats OK?
