electric telescopic aerial connection
brooky
Car(s): 2.0 Laser and XR4x4i.
Post by brooky »
Hi
Where does the blue wire which powers the telescopic aeriel go to on the radio of a 2.0 laser
Mark
Re: electric telescopic aerial connection
Did they come with one??
brooky
Post by brooky »
no idea but its got one now, the original radio is fitted which has positive lead and a yellow lead.
Yellow is probly battery back up, maybe 😁
T.M.
Post by T.M. »
some photo will be helpful. Which radio do you have? ESRT32 PS?
There should be pin at the back, on which is 12V only when radio is on. Originaly it was white wire, which goes from this pin to automatic aerial.
Tom
brooky
Post by brooky »
It is the earlier rst21p radio
T.M.
Post by T.M. »
So PIN for automatic aerial should be next to "+" PIN.
On picture there is Blaupunkt Coburg Stereo, but it is same radio as RST21P.
Tom
brooky
Post by brooky »
Hi tom, that would make sense as mine had the aeriel wire just stripped back so it was probably just pushed into that auto aeriel power socket, do you know what type of connector is needed for that end rather than just bare wires being pushed in
T.M.
Post by T.M. »
I have there "flat type" connector, about 3mm wide (i think), male on radio, female on wire to aerial. Something like on pictures.
But I also find picture where some circular conector is instead of flat type. But I don't know what's that, just find picture...
Tom
brooky
Post by brooky »
All working yellow wire was ignition feed to radio, small terminal switch power to aerial. Thanks all
T.M.
Post by T.M. »
Great! ;)
Tom
