Thermostat replacement on a 2.8 injection
Shadyshent
Car(s): 2.8 injection running restoration
Post by Shadyshent »
Hi I am new to the capri and I am replacing the thermostat on my 2.8 injection I sent for a gasket set for the stat housing which has got two gaskets but no o ring , the question is should it have one or is it ok to put it back without one , many thanks Andy
Re: Thermostat replacement on a 2.8 injection
Shadyshent wrote: Sun Apr 24, 2022 9:34 am Hi I am new to the capri and I am replacing the thermostat on my 2.8 injection I sent for a gasket set for the stat housing which has got two gaskets but no o ring , the question is should it have one or is it ok to put it back without one , many thanks Andy
Hi Andy,
The rubber seal should be supplied with the gasket set.
https://www.capriclub.co.uk/Thermostat_ ... --228.html
https://www.ebay.co.uk/itm/264501058792 ... SwLM5a~Hmx
Make sure you have been supplied the correct 82 degree thermostat, as some motorfactors will supply an incorrect one.
Capri specialists will know what's what and will supply the correct part.
Welcome to the forum, by the way ! :welcome:
Shadyshent
Thanks for the reply it’s a learning curve with the capri and I want to get it right because it was getting hot after about 15 mins of running but I found a few blockages on the small hose connections , so hope all will be well when it’s back together 👍
Hi , good on you for having a go . If you have had some blockages it may pay to give your cooling system a bit of a flush out....specially if it full of rusty looking water instead of nice clean coolant. If you have a garden hose with a good water supply thats probly all you need . I usually undo hoses and shove the garden hose in so it pushes water in the opposite direction ( reverse flush ) thru various parts of the system. And do it somewhere where rusty water pouring out wont get you shot coz its bloody hard to get off concrete or cobble driveways .
I am not familiar with the 2.8 but if there are any tricks to flushing this motor some other brain box will probly give up their secrets 😁..........we are like that 😆😊😊
Something else we like is to hear how you get on after the job is done.......even if nothing goes wrong and it all seemed a bit ho hum 😆
Shadyshent
Thanks any advice is useful and thanks for your time , when I took the old stat out there was no rubber o ring on it but the new stat has 2 on o ring and a square edge rubber but not sure where they go ?
Shadyshent wrote: Mon Apr 25, 2022 2:51 pm Thanks any advice is useful and thanks for your time , when I took the old stat out there was no rubber o ring on it but the new stat has 2 on o ring and a square edge rubber but not sure where they go ?
The seal with the square profile fits between the thermostat and where it sits on the block. I'm not sure about the o ring. Is it the same size as the other seal?
Shadyshent
Yep I have tried it on the water pump housing but they seam to be to big so I wondered if they are for different car because they used this engine for a few makes
T.M.
Post by T.M. »
I also think that o-ring is for another car.
Here is picture of instalation to 2.8i. ;)
Tom
thermostat 2.8i.JPG (20.4 KiB) Viewed 1291 times
T.M. wrote: Wed Apr 27, 2022 6:49 pm Here is picture of instalation to 2.8i. ;)
That's great Tom, thanks.
I got it the wrong way around in my reply!
T.M.
Post by T.M. »
Andrew 2.8i wrote: Wed Apr 27, 2022 6:51 pm That's great Tom, thanks.
I had to check it in workshop manual. I was affraid that I have it wrong way on my 2.8i. :)
Tom
Shadyshent
Morning Tom thanks for the info the stat is back on now but before I refilled water I noticed that the hose that goes from the from the top of the block to the back of the thermostat needs replacing so have ordered one but it was a pig to get off so was wondering if you had any tips to replace it , it looks impossible cheers
Andy
T.M.
Post by T.M. »
never do this hose, so no tips, sorry.
Tom
I don't have a 2.8 so can't help on the hose, but just wanted to check about the O ring you mentioned - I've had to change mine recently and the thermostat came with a piece of rubber around the edge of it - if that is what you mean then you need to take that off before fitting in the car :)
