Gearbox mount modification
Jumper
Car(s): Mk 3 1.6GL
Post by Jumper »
Does anybody have any picture of the gearbox mount modifications needed when changing from a 4 speed to 5 speed (T9) gearbox? Cheers
Re: Gearbox mount modification
You may need different propshaft too. Most boxes are 23 spline, but some 4 speeds are 20 spline. What box are you replacing?
STEVEW
Car(s): Ford Capri 2.3S
Project
Post by STEVEW »
Hi Jumper,
https://postimg.cc/bS1N4mtR
https://postimg.cc/zVDjz6x6
I hope these help.
PS
This shows how my son and I solved this problem.
The centre section is welded to the side sections by using two 20mm dia. lengths of steel tubing. This set up should give you the strength, the front/rear offset plus the difference in height you could need.
PPS: It's fitted to a V6 Cologne
Jumper
Car(s): Mk 3 1.6GL
Post by Jumper »
Thanks Major Tom & Steve - a big help. I am replacing the standard 4 speed box and I do need to replace the propshaft - different number of splines and a different length, I think. Thank you.
