(Im getting a new one .....that I can use my phone to program )
Car alarms
Re: Car alarms
Yeah , but its not like we went over the top or anything.
, go on , pull my leg
,if you get the wrong one it will probly come right off
Re: Car alarms
A programmable leg? You mean a bit like the bump and rebound settings on a shock absorber?
Re: Car alarms
I'm genuinely interested! Is it programmable knee stiffness or what?
I could just look it up, but I don't like doing that as it demeans the importance of human interaction.
Re: Car alarms
First rate punnage
Re: Car alarms
The one I have has a hydraulic dampener in the knee , controlled by electric valves which are in turn controlled by a processor . The knee stiffens up when straight ....not solid . When I put weight on my toe , as in walking the knee unlocks and bends freely untill it stops bending ( whatever the angle )and from there it will straighten freely but be real stiff to bend untill the pressure is on my toe and it unlocks again so I sorta walk like I kicking a can along the path . When its stiff straight it still creeps a bit , this allows me to sit down and the further it creeps the less the dampening so it sorta accelerates . If Im standing around I dont feel it creeping till its to late and it has dumped me on my arse a few times.
The new one just has a lot more brain power . I can set the range of motion for different situations like riding the bike . I can set the dampening to change according to degrees of rotation and it has more sensors in the heel and knee . Can be programmed for uneven ground and is waterproof.
Re: Car alarms
That's awesome. You should experiment with it, test out various settings, until you find the ideal parameters for the perfect kick in the bollocksMc Tool wrote: βMon Mar 14, 2022 11:20 pm The one I have has a hydraulic dampener in the knee , controlled by electric valves which are in turn controlled by a processor . The knee stiffens up when straight ....not solid . When I put weight on my toe , as in walking the knee unlocks and bends freely untill it stops bending ( whatever the angle )and from there it will straighten freely but be real stiff to bend untill the pressure is on my toe and it unlocks again so I sorta walk like I kicking a can along the path . When its stiff straight it still creeps a bit , this allows me to sit down and the further it creeps the less the dampening so it sorta accelerates . If Im standing around I dont feel it creeping till its to late and it has dumped me on my arse a few times.
Re: Car alarms
Dunno about kicking bollocks , old joke about one legged man at arse kicking party, but I gotta watch I dont kneel on my dick .....leg being a bit shorter
Re: Car alarms
You must have used your RAF experience to fly under the radar !
Re: Car alarms
Andrew 2.8i wrote: βSat Mar 19, 2022 7:54 pmYou must have used your RAF experience to fly under the radar !![]()
And after all my years of membership, this post has finally prompted me to upload an avatar.
ZA601 in which I got a back seat trip in Jan '93, piloted by Sqn Ldr Hillier, now Sir Stephen Hillier who ended up as Chief of the Air Staff.
Obviously my couple of hours chatting with him set him up nicely.
Re: Car alarms
Theres something about a Tornado, and the same goes for the Spitfire and Lancaster as all iconic aircraftBug wrote: βMon Mar 21, 2022 10:54 amAndrew 2.8i wrote: βSat Mar 19, 2022 7:54 pmYou must have used your RAF experience to fly under the radar !![]()
Andrew.![]()
Obviously my couple of hours chatting with him set him up nicely.![]()
I really dislike flying, so annoyingly if I was offered a ride in one of these I would have to turn it down
Re: Car alarms
I've always loved the Mosquito
