Heater Box Removal
Heater Box Removal
In the latest CCI magazine, there is a walkthrough on removing the heater box, but it is stated that you need to remove the steering wheel, the stalks/switches and the centre console. Certainly, I've had the box out without taking out any of those. My point is, what's he on about?
Re: Heater Box Removal
Sounds weird - not read it yet. Surely just take the glove box out is the easiest way.pbar wrote: ↑Fri Feb 04, 2022 5:08 pm In the latest CCI magazine, there is a walkthrough on removing the heater box, but it is stated that you need to remove the steering wheel, the stalks/switches and the centre console. Certainly, I've had the box out without taking out any of those. My point is, what's he on about?
Sorry to be a pedant, but that article was in January's magazine, not the latest one.
You know, just in case somebody tries looking for it.
Andrew 2.8i wrote: ↑Fri Feb 04, 2022 8:03 pmSorry to be a pedant, but that article was in January's magazine, not the latest one.
Thanks, yes, the January one it is. Been meaning to post this for at least a couple of weeks! Although that will be the latest for many of us.
I can tell you that you certainly don't remove the console, steering wheel or the stalks in order to take out the heater. I've done hundreds of them and only once did I disturb the console and that was on a 2.8i that had been fitted with a massive air conditioning unit.
I look forward to reading the letter from "Angry from Stockport" on the letter's page of the next mag !
I'm sure this is his intention, as he goes on to describe the next stage of the fix if replacing the switch didn't work "if no luck, then proceed by taking the glovebox assembly out........now you are almost ready to drop the heater out".
Anybody wishing to change the heater motor, matrix and/or seals, can skip the early steps and follow the instructions on removing the glovebox and centre console to access the heater box.
The way I interpret the article, John is saying if the heater is not working, the fault is most likely to be the two-speed switch. John does not state that the steering wheel etc have to be taken off to remove the heater box, he's simply suggesting a way to access the most likely broken part and keeping the heater box in-situ during the process.
Andrew 2.8i wrote: ↑Sat Feb 05, 2022 7:24 am I look forward to reading the letter from "Angry from Stockport" on the letter's page of the next mag !
I tried being angry a couple of times Andrew, it didn't suit me, so now I just try to be endlessly happy Thanks for your interpretation of the article, you're probably right. Strangely enough my latest mag came today, so now you are definitely right about that!
Caprigear wrote: ↑Fri Feb 04, 2022 10:52 pm I can tell you that you certainly don't remove the console, steering wheel or the stalks in order to take out the heater. I've done hundreds of them and only once did I disturb the console and that was on a 2.8i that had been fitted with a massive air conditioning unit.
Thanks for your input Martin, valued as always. Although often dreaded, the Capri heater box isn't that bad to remove in my opinion and it's a job worth doing. With some cars, as I'm sure you know, it can be a nightmare with the whole of the dash etc. having to come out
