Door removal Mk3
Timo20
Car(s): Capri MK3 1.6GL
Door removal Mk3
Post by Timo20 »
Hi looking to remove the drivers door of my MK3 by removing the pins.
Is this possible and is the Sykes pickavant tool the best for the job, also does anyone know what diameter the pins are?
Also I have some rust around the top hinge of the door, is this common and is it repairable as the door is overwise perfect.
Many thanks
Re: Door removal Mk3
Hi, there has already been replies to your other thread on this.
Timo20
Post by Timo20 »
You are correct, i didn’t realise it got posted.
Still after a reply regarding the door rust and hinge pins though
Post by Caprigear »
You'd be better off unbolting the door from then car then try to remove the pins once it is off the car.
Caprigear wrote: Thu Jan 20, 2022 1:08 pm You'd be better off unbolting the door from then car then try to remove the pins once it is off the car.
As per the other thread! ;)
