High torque starter for 2.9
80s-new-man
Ford Sierra XR4x4 2.9 1992
Jaguar XJR SC 4.0 2001
Post by 80s-new-man »
Hi all.
I was thinking of upgrading the starter on my 2.9 BOB engined special… it always seems a tad lethargic when cranking. I think maybe it’s the original.
As the engine is the Scorpio Cosworth 2.9 I am after a high torque starter to fit. Can anyone recommend a good specialist? I tried the usual suspects like burton etc but they didn’t seem to on their sites.
Sierra XR4x4 2.9i 1992
Jaguar XJR 4.0 SC 2001
Jaguar F-Type 3.0S sc 380
Re: High torque starter for 2.9
It's usually only high compression 4-cyl engines that need high torque starters.
Post by Mr B »
80s-new-man wrote: Fri Dec 03, 2021 4:38 pm Hi all.
Hi mate,
High torque starter motor's are great, I have one on an Essex V6...... but be warned unlike the standard starter motor they do not have the provision on them to send 12 volts to the coil during cranking.
On my car i had to run a separate switch to feed the coil 12 volts during cranking, without this she was seriously hard to start especially on cold mornings, admittedly running a switch is no big deal but I just want to make you aware that its not a take one off and put one on jobbie.
Not sure the above applies to the set up you have though.
80s-new-man
Appreciate the info guys..
I suppose there’s reasons there why I cannot find any…
I guess then, it may be just good to get a brand new replacement?
