Straightening my bendy
..any good ideas about straightening a warped rocker cover effectively? I bought a rubber rocker cover gasket last year and whilst it's great at being a gasket, it sticks to the cylinder head exhaust side and you basically have to butcher the rocker cover to get the bloody thing off.
Re: Straightening my bendy
Hopefully this will help you Tom
https://www.google.com/search?q=jeremy+ ... 029rU,st:0
You could do with some 1/3" square bar so you can put a piece either side and crush it back into shape in a vice, preferably or a mole wrench, possibly?
Once the metal has stretched ,which it must have if its buckled out of shape , its nearly impossible to un-stretch . Probly easier to just get another cover . If we are talking pinto motor ,so many of them have been wreaked ( being as how they are the worst motor in the world Jason ) they must be stacked up pretty high by now . Any how , I believe Nick may have one he's not using
Shame about the gasket sticking so bad . Maybe a smear of hi temp grease ,like copperslip might help stop sticking .
Thanks for replies.. will have a go at it and see how it turns out!
I'm pleased I've only ever used the traditional cork ones, those from CCI seem great.
Good luck with it though Tom.
I only tried a rubber one because I thought it would help with the leak I had due to a warped cover in the first place it worked great until it came to checking valvev clearances and couldnt get it off!
I do indeed
Tom you can have this mate. Its the wide lip later one. Dont recall it leaked when i had it so hopefully its all good. Dont want no money fella. Just be really glad it will go to a good home rather tban sit in my garage. As said its yours if you want it Tom. Just pm me your full name and address and ill send it.
Don't give Tom your address Nick whatever you do - there will be all sorts of things turning up!
I was only joking Nick , but if your old one finds a good home .....Fordoholic Nick wrote: βWed Aug 25, 2021 7:08 pm
I do indeed
Things like this are good . I gave a small base guitar amp to some guy on the hunting and fishing website I post on , Di's brother gave it to me , beats me why as the only musical instrument I play is the stereo . Easy come easy go .
My friend gave me his left over lounge flooring wood , which was enough to do my kitchen .....so it works out
PM sent Nick!!! Thanks a million!
