Water leak
-JC-
2004 Mazda RX8
Water leak
Post by -JC- »
I thought I'd cured this, but sat in the back the other day when it was pouring with rain out, and I could see a dribble from near the boot hinge mounting point passenger side. Is that likely to be a sunroof drain pipe issue? Any easy way to fix?
Re: Water leak
I think I have this same issue, bloody annoying, fills up the inner wing with rainwater!
Supercharged Nat
Re: Water leak
Post by Supercharged Nat »
The rear washer jet springs to mind, as a place for water to get in or maybe a split in the pipe and so leaking when used?
The sunroof / drain could also be a source but im unsure of the route the pipes take?
Re: Water leak
Supercharged Nat wrote: Wed Aug 25, 2021 6:31 pm The rear washer jet springs to mind, as a place for water to get in
Good thinking that man!
Allan mcl
Re: Water leak
Post by Allan mcl »
Is the washer jet not on the drivers side?
Re: Water leak
Rear washer jet is on the passenger side under the side wheel cover
Re: Water leak
Allan mcl wrote: Fri Aug 27, 2021 7:59 pm Is the washer jet not on the drivers side?
My leak is on driver's side 👍
Allan mcl
Re: Water leak
Post by Allan mcl »
The jet is on the roof, the bottle is the boot.
-JC-
2004 Mazda RX8
Re: Water leak
Post by -JC- »
Mine is passenger side. Not the bottle either, it's higher than that
