Damn, he was right!
Damn, he was right!
I had an mot advisory back in February as there was a sign of cracking around a driver's seat mount on the 2.0. Finally got around to having a look. Another little job to do!
Re: Damn, he was right!
Time to start that diet!
Is that just stress or is there some corrosion on the other side too? Something else to worry about.
What would be the cause of a crack like that?
Just weakening of the metal over time?
I would think so Andrew, it's gone along the edge of the reinforcing plate underneath. Maybe need to slow a bit more on the cornersAndrew 2.8i wrote: ↑Thu Jul 15, 2021 7:03 pm What would be the cause of a crack like that?
Looks OK underneath Steve. I'll clean it up to make sure but looks like a stress crack to me.
What's your plan with that Peter, fill the crack with an eventual line of weld? Nice straightforward fix if that will do it.
That's quite a common failure point. We see it on most of our builds.
Hi steve,
I had a similar problem.
Like you I cleaned and degreased around the cracks after which my son welded them. The welded joints were treated with rust inhibitor.
Plates (x4) were made up and welded on from above.
The finished areas were then sprayed with zinc.
I believe the problem is both fatigue and a little corrosion.Is that just stress or is there some corrosion on the other side too? Something else to worry about.
They are pretty flimsy though . Silly thing here is that that sort of mount would pass wof (mot ) on a factory car .... but would be rejected on a scratch build or heavily modified car , you would have to fit 4mm plate of a minimum area ( not sure how big )
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
Clean the crack out with a Dremel or similar Peter and then drill a hole at either end of the crack to “terminate” it. Fill with weld (I’d just MIG it) but you’ll need to be careful of getting too much heat into it. Ideally use a heat sink and be careful of welding too long a run at once.
Thanks Mark. I've been using a dremel type thing to clean it. I'm confident I can drill the holes that just leaves the other bit!mjcapri wrote: ↑Sat Jul 17, 2021 8:00 amClean the crack out with a Dremel or similar Peter and then drill a hole at either end of the crack to “terminate” it. Fill with weld (I’d just MIG it) but you’ll need to be careful of getting too much heat into it. Ideally use a heat sink and be careful of welding too long a run at once.
Peter,
I`ve been trying to work out which mounting point that is, I`m thinking rear but is it left or right?
Yes Steve, rear of driver's seat next to the tunnel
I'm going to put this in the car when I'm done
Just make sure they know you're talking about the car............you are aren't you?. Ah ha ha ha ,just realised that sticker would be better on my car, yeah , that could be real funny
Hamish, there's days when I'm not really sure
