Wings
shrule
Car(s): drive 73 yellow 1300 facelift with a 2000cc engine
and a 76 V W beetle
Wings
Post by shrule »
Is it a problem to remove the front wings from a Mk 1 facelift Michael
Car(s): 2.8 Injection 1983 5 speed, weekend car. Audi A7 daily driver Slowly restoring a 1979 MGB. Previously owned 2 Capris.
Re: Wings
Post by Not_Anumber »
It would be if the owner caught you trying it. :kungfu:
This is the parts for sale section
shrule
and a 76 V W beetle
Re: Wings
Post by shrule »
Good joke I am the owner and need to remove them in order to re fabricate round the head lights and check for other rust spots any ideas ???
Re: Wings
Post by stevemarl »
It depends, if you`ve worked in a bodyshop for 30 years it`s no problem: if you`ve never used an angle grinder it`s a massive problem.
This covers it, the mk1 will be basically the same.
https://www.dailymotion.com/video/x5tzclf
shrule
and a 76 V W beetle
Re: Wings
Post by shrule »
Thanks Just need to know for when I take it to body show thanks again
Re: Wings
Straightforward job for a body shop really, Especially if they've worked on older cars. Certainly, many people change the wings themselves.
Re: Wings
The toughest part is trying to get pattern part wings to fit. Have you found a source ?
shrule
and a 76 V W beetle
Re: Wings
Post by shrule »
Hope to take them off and send them to Steadspeed restoration in Scotland. Spoke to owner who will restore them
Re: Wings
Thanks for the update. You don't hear of that very often, taking original wings off, having them restored then put back on. Great idea.
Re: Wings
Post by stevemarl »
It makes sense really, if you havethe skills (or know someone) as 95% of the panel is usually solid, it only needs very specific areas replacing. I`ve often thught it might be better to use parts of an aftermaret as repair plates for the original wing. Especially considering how hard it can be to get a proper fit.
Re: Wings
Completely agree with you Steve, as you know I've repaired a wing previously. It's just that it is nice to see a make do and mend repair approach, as opposed to I'll Just buy a new one, which is more the philosophy of this modern age with most things.
Good on you Michael, hope it works well for you.
