Windscreen Woes
Re: Windscreen Woes
The trim and corners spread the seal apart , fits more securely and it pushes the outer edge of the seal closer to the painted surface . This trim ,I believe , was only on the mk1 ( someone mention this above ) and that is the diff between mk1 and mk2 seals. Google it up and see how its done , vid is worth a thousand words an all that .
Re: Windscreen Woes
Think it was on Mk1 & Mk2, but not Mk3Mc Tool wrote: βThu Jun 17, 2021 9:48 pm The trim and corners spread the seal apart , fits more securely and it pushes the outer edge of the seal closer to the painted surface . This trim ,I believe , was only on the mk1 ( someone mention this above ) and that is the diff between mk1 and mk2 seals. Google it up and see how its done , vid is worth a thousand words an all that .
Re: Windscreen Woes
Yeah , your probly right , I am not really familiar with either mk1 or 2 . I dont really like the trim , sorta traps you into matching the rest of the car to the chrome thing ......spose you could paint the trimBug wrote: βFri Jun 18, 2021 7:31 amThink it was on Mk1 & Mk2, but not Mk3Mc Tool wrote: βThu Jun 17, 2021 9:48 pm The trim and corners spread the seal apart , fits more securely and it pushes the outer edge of the seal closer to the painted surface . This trim ,I believe , was only on the mk1 ( someone mention this above ) and that is the diff between mk1 and mk2 seals. Google it up and see how its done , vid is worth a thousand words an all that .
