Sill Drain Holes
Sill Drain Holes
Could someone please explain where the sill drain holes should be? Or show a pic. The Capri has sunroof plastic pipes which end inside the sill area, so rain is effectively poured into the sills (good idea!) which must then drain off somewhere. I know that some people extend the drain pipes so rain runs straight onto the tarmac which sounds better.
- Car(s): 3.0 Ghia
Re: Sill Drain Holes
Great pic, explains it very clearly
Thanks Steve, never knew those D shapes signified the holes, interesting info that.
You couldn't take it a step further could you please, and (probably easier to use a stock pic off the internet?), using a full side view of the car mark on the positions of the drain holes please.
It's info which I just can't seem to find anywhere.
Thanks Steve, yes that's why I mentioned perhaps using a stock image off the internet, to mark them on.
Edit: You beat me to it, thanks Steve that's great
The very first hole, I assume that's like a 'double' hole then, it goes through the sill and also through the bottom of the wing? (As the wing flange overlaps the sill in that area)
I couldn`t honestly say Paul, I would assume so but you can`t really see? In fact, yes, looking again, the wing `overlays` the sill so it must.
Thanks Steve, I bet a lot of people inadvertently cover that one up when fitting pattern wings, assuming those don't come with a corresponding hole.
Seems such a strange idea to purposefully allow rain to enter the sills, it's a wonder that any of these cars are left!
I agree, it can`t have been that difficult to simply extend the tube down through the sill. I think though that when new, the pipe does empty pretty much straight above the drain holes, so providing the inner surfaces have been treated (Ziebart/DiNitrol) and the drains kept clear, it`s not that big a problem (also when new the sunroof seals maybe kept out the bulk of the water, the drains just stopping the odd drip entering the cabin? It`s when the drain holes (which are only small ) get clogged, then the sills can fill with water which can`t drain out. How many people would have checked the drain holes were clear every service? Apart from me - after owning a VIva!
And I bet that loads of people who had their cars professionally (or diy) undersealed, had those holes clogged/filled up.
Oh absolutely! any kind of wax in the sills will clog the holes, which many wouldn`t even be aware of. You need to probe them afterwards to lear them. Again, how many did?
These were just everyday cars, no-one really thought of them as they do now, `icons of the `70s` etc, they weren`t really cared for, most were just owned for a couple of years then traded in: by the 6th owner it`s probably getting a bit, how can I put it.... you`ve seen the end of `Black Beauty?
You made me Google it -
After a traumatic downfall and coming close to death from overwork, Beauty at last finds a home in a beautiful spot with people who will care for him for the rest of his days.
Very apt!
Very apt!
Regardless of the factory drains I drilled 8 mm holes directly under where all the sunroof pipes were so water would drain straight out. I also waxed inside the sills and after a few weeks I poked out the factory drains so they could flow if necessary.
Good idea Paul, and very wise too. I may just do something similar.
You could test the sill drain holes by spraying WD40 into the drain holes in the sunroof surround. You should see the WD40 dripping out, if not, the holes or tubes may be blocked.
You all seem to have missed the fact that Paul looked out his window at the crappy weather and thought, "I know, I'll get someone else to roll around under their car for me, while I sit in the dry with my laptop and a hot cup of cocoa."
Martin that is totally untrue and I resent that - it was a latte
