Just changing my accumulator, pipe onto unions have got a bit squashed
How are they fitted into unions are they just warmed up and pushed on,thinking I could cut a 1" off and push on
Tony
Accumulator
Re: Accumulator
The standard unions are barbed and it's very difficult to push them on. When you think that the operating pressure of the system is 79 PSI (5.5 BAR), it's probably a good thing that the pipes don't come off the unions easily!
The short fuel line that goes to the pump should be easy to remove. You can then make sure it's completely drained of fuel before using gentle heat to expand it before trying to push on the new union. You'll have a problem doing that with the line that goes to the fuel filter. When they built the Capri, Ford lay the fuel line on he floor and built the car around it! Seriously though, you can't undo that one as the connections on the join in the fuel line under the nearside front wing are too big to pass through the hole in the floor strengthener.
I wonder if there is a tool available to push the barbed unions onto the fuel lines?
Re: Accumulator
Best leave them as they are then,hopefully not to squashed
- Car(s): Ford Capri Cabaret 1.6,Ford Cortina MK5,1992 Ford Sierra Coupe,1988 Ford Sierra Coupe.Ford Sierra XR4i
Re: Accumulator
Use a pipe flaring tool. Or,leave the accumulator off,it's just a fuel dampener.
Re: Accumulator
Not exactly.
It does indeed dampen out fluctuations caused by the pump.
It's other function is to maintain pressure in the fuel system when the engine stops. Without this, the pressure dissipates, meaning it is very difficult to then start the car until the pump has managed to catch up again.
If you swap the fuel pump relay for a Lucas one, it will run for a second or two when the ignition is first switched on, helping to prime the system, which may compensate for a lack of accumulator to a small degree.
However, maintaining the pressure in the system also helps prevent the fuel from evaporating. Without an accumulator, the fuel will disappear over time which can lead to seals drying out, the metering unit piston seizing and many other undesirable side effects.
Don't leave the accumulator off.
Re: Accumulator
very informative. I have not experienced it without the accumulator,I know several XR4i owners who had issues with the fuel system. The accumulator was removed and the 4i driven betterBug wrote: ↑Thu Jul 02, 2020 7:18 amNot exactly.
- T.M.
Re: Accumulator
last year I bought new original pink fuel pump relay from Ford dealer and it makes that pressurization too, when you switched on ignition. Previous non-original (onknown brand) relay didn't make it.
Tom
