I decided I wanted Halo lights on the front of the Capri. I could have gone down the route of installing BMW E46 lights that already have halos in them, but I didn’t want to go down this route. Obviously to do what I wanted to do, I would need to separate the glass from the reflectors. Could it be done? On searching the web, I found that this was possible by heating them up. Now since my car is a daily driver, I didn't want to carry this out using the current headlights. In my experience, if anything can go wrong, it will! With this in mind, I obtained another set of headlights from Martin at Capri Gear to carry out all the work on them prior to swapping them over when completed.
Phase one was to separate the glass from the backs and so enter the family oven, much to my wife Marie’s disgust and heated to 180 degrees. The headlights were placed inside one at a time for around 15 minutes each. When nicely cooked, the light was removed and using a small kitchen knife, a screwdriver is too big to use, the knife is taken carefully around the edge of the glass lifting it and slowly separating it from the reflector until completely removed. It’s then left on a cooling tray to cool down while I proceeded to carry out the same process on the other lights.
Phase 2
A notch needed to be cut in the reflector so that there was room for the halo wires. On the lights backs there are two notches that corresponds with notches on the glass. I cut the wire notch directly opposite these. You could drill the reflectors and pass the wires through this way, but I decided to not do this.
I used 125mm halo lights although you could get away with 130mm ones. These are readily available on Ebay or elsewhere on the web and the cost is pretty minimal, £12 a pair. Cheap eh? To put the halos in, a bead of Super Glue was placed inside the reflector and then another bead of silicone sealer was run around the edge off the halo to make sure that it wouldn't move. Finally, a bead of silicone sealer was run all around the edge of each light, the glass was reinstalled and weighted down until completely set.
When everything was in place and dry the whole set of Halo lights were wired up and tested to make sure they worked OK.
Phase 3
Next up was the final installation so I installed the headlights one at a time wiring everything up as I went. I have the halo lights wired up to a separate switch on the dash so they can be used as daylight running lights. You could indeed wire them up to the side lamps. In daylight you get the enhanced looks of the Halo, over the pretty useless side lamp..
But if you fit the negative leg of the Halo in the outer set to the yellow wire of the dip beam lamps, and in the inners, to the white wire of the mains ...you switch on the sidelamps, halos are on ..switch to dip beam, the outer Halos go out with the dip beam, inner lamps remain with Halos ..
switch to main beam and the Halos in the inner lamps extinguish as well ..It's up to you!
This mod won't be everyone's cup of tea and the purists will absolutely hate it, but I'm pretty happy with the result and plenty of others have appreciated what has been done.
Project Halo
Re: Project Halo
I'm not usually keen on too much modification but I have to say I really like what you have done. My only question is has the beam pattern been altered for MOT purposes?
Re: Project Halo
I can't actually see the pictures, presumably as I am not a member of the other forum they seem to be linked to.
Re: Project Halo
Ditto, I'm just getting a little image failed logo
Re: Project Halo
I can't seem to post pictures of them so they appear on here. Any ideas? I used to use photobucket but thats crap now.
Re: Project Halo
I wrote this some time ago, but it still applies -
2. Click Choose Images
Re: Project Halo
OK Thanx. I can't find any edit button anywhere for the original post, so here are the pictures in orderpbar wrote: ↑Thu Feb 13, 2020 7:09 am I wrote this some time ago, but it still applies -
