Door Lock: Removal and Reassembly
Re: Door Lock: Removal and Reassembly
Post by D366Y » Thu Oct 24, 2019 4:22 pm
Thu Oct 24, 2019 3:59 pm
Thu Oct 24, 2019 8:19 am
It worked!
Good work, fella! :D
Dare we ask what stage 2 involves?
I was rather hoping you'd tell me - I'll be following your guide! :lol:
Looks like I need to remove a circlip of some sort.... :D
Post by Andrew 2.8i » Thu Oct 24, 2019 4:39 pm
You've done the hard bit, it's plain sailing from here....
Perhaps the roll pin bit was difficult because you weren't wearing your lucky stripy socks! :lol:
Post by pbar » Fri Oct 25, 2019 6:28 am
Thu Oct 24, 2019 3:02 pm
Thu Oct 24, 2019 2:08 pm
I've been following this thread like a TV soap addict glued to the box awaiting Emmerdale's next instalment. So I'm pleased to see that piece of good news Danny :) You must be relieved.
Just glad to be done with this small saga so I can get stuck on step 2 instead of being stuck right at the start :lol:
You seem to take it all in your stride though Danny 8-)
Post by D366Y » Sat Oct 26, 2019 9:06 am
Haha unfortunately for me those socks have basically had it - need to find some new lucky socks with less holes :lol:
If I didn't laugh I'd cry so I just keep plodding on haha
Post by Andrew 2.8i » Sun Oct 27, 2019 7:58 am
That explains the run of bad luck you're currently having! :lol:
Post by D366Y » Mon Nov 04, 2019 6:55 pm
Hi Andrew,
Two quick questions....
1. the washer you mentioned at the keyhole end of the barrel that could be replaced with a fibre washer - do you have a link where to get a fibre washer or replacement from at all? Mine are buggered!
2. When I finally get to the end do I have to have a cuppa or can I have something a bit stronger? (I think I've earned it!! :beer: ) :lol:
Post by Andrew 2.8i » Mon Nov 04, 2019 7:03 pm
Hi Danny,
It's good to hear that the project is nearing completion! Is the deterioration of the washer the cause of the lock issues? Mine was, as the in and out movement of the barrel allowed the spring to jam between the barrel and the housing.
1. I just used some washers I had lying around, but you could measure the size required and buy some from Ebay or any other DIY outlet.
This seller should have something that will fit:
https://www.ebay.co.uk/itm/FIBRE-FLAT-S ... 5d5e2e2748
2.Depends if it's a school night or not! :lol:
Post by D366Y » Tue Nov 05, 2019 8:50 am
Hi Danny,
I think it must have been the issue - hard to tell when there was so much grime and crud everywhere!
Thanks for the link, i'll measure what I have left later (it was cracked and missing a section, when I took it off it broke in two!) and see if they have a serviceable part :)
I think school night or not I've earned it :lol: :beer:
Post by Andrew 2.8i » Tue Nov 05, 2019 12:27 pm
Instead of trying to reconstruct the washer, it might be easier to measure the diameter of the barrel and buying a pair of washers with the same I.D. as that measurement. If the O.D is too big it should easily be trimmed to the correct size using a sharp craft knife.
There isn't anybody on here who wouldn't agree with that. As you wrote earlier, you never seem to get a break!
Post by D366Y » Tue Nov 05, 2019 1:44 pm
Great idea Andrew, I'll measure the barrel instead :cool:
And I know! the sunroof started leaking yesterday so that's always good, but I did repair the rear wiper the day before so I shouldn't be surpised really; fix one thing and the next thing will break immediately afterwards :lol:
