I was planning to leave the cam in place, but since I'm going to give the head a thorough clean I figured I'd remove it. But, I can't get the pulley bolt undone.
Head is off the block, stripped of everything except the cam. Any tips on undoing the bolt without the cam turning?
Ta
Pinto Camshaft Pulley Bolt Removal?
Re: Pinto Camshaft Pulley Bolt Removal?
Can you put a screwdriver/metal bar through the cam pulley from the front. It should wedge on the head and stop the cam turning.Cosmicbike wrote:I was planning to leave the cam in place, but since I'm going to give the head a thorough clean I figured I'd remove it. But, I can't get the pulley bolt undone.
Ta
