faded sunroof seal
faded sunroof seal
Hi all,
I noticed at Brooklands yesterday that my sunroof seal was fairly faded but as it was still in good condition I did not want the hassle of removing the sunroof to fit a new one, as the sunroof works really well and usually if you mess with something that works fine 'before' it don't wotk fine 'after' :wave: :lol: .
So I set about trying to find a solution and I seem to have found it with a product - Autoglym Bumper and Trim Gel. Unlike other spray applications this is a gel so much easier to apply neatly and direct to the area. This is stuff...
Image20170522_155507 by nicholas bowler, on Flickr
I used as artist type brush to carefully apply it
Image20170522_155602 by nicholas bowler, on Flickr
Which when lightly depressed on the seal it spread to just the right width. I used a spare cap to use as a container to hold the gel
Image20170522_155620 by nicholas bowler, on Flickr
So I dabbed the brush in the gel and worked it into the seal well in inch long sections at a time so it will take a bit of time to work your way around the seal but why rush it and do a less good job. I actually went around twice as by the time I did the first coat it was dry and it seemed to give it an even better finish, but you may be happy with just the one treatment.
Here is a pic of a section before and after. Hope you can make out the difference it makes and this was just one treatment...
Image20170522_155659 by nicholas bowler, on Flickr
Sorry guys, the shine on my car is reflecting the white roof of my garage so hope you can see the sunroof seal ok :lol:
So as said I treated it twice and it really made a big difference to the faded seal and it does not harden the seal as this gel is designed for rubber too so keeps things flexible and soft. I ended up with a much 'blacker' look to my faded seal so just thought I would share this with you in case you may have a similar concern.
Hope this is of interest.
PS Sorry O got interrupted and forgot to take a 'finished' picture but hope you can see how the product does darken the seal :)
Re: faded sunroof seal
Post by Caprifan Rob »
Where was this advice before I went to the trouble of changing my seal Nick?? ;)
Looks quite good actually :D & as you say, it remains supple, will probably prolong the life of the seal too.
Noel
Car(s): Capri 2.8i
M140i
Post by Noel »
Must get me some of this as mine is getting a bit grey.
Guessing this is good for the tailgate spoiler as well?
Caprifan Rob wrote:Looks quite good actually :D & as you say, it remains supple, will probably prolong the life of the seal too.
Cheers Rob. As said this was only one treatment too and it does look better even in the flesh. Going over it a second time gave it an even better finish and as you pointed out it will probably give it some protection too. Very impressed mate and no need to replace a perfectly good seal :sorry: :lol:
Noel wrote:Guessing this is good for the tailgate spoiler as well?
Yep, Noel I treated my rear spoiler with it last week before Brooklands and that came out pretty well too fella. Very easy to apply mate. Also did the side moulding trims too but check it out on a small area yourself just to make you you like the finish :)
All the best now
Nice Top Tip there Nick and that shine on your car is 10 out if 10 .
I will be doing this as I guess it helps the rubber from drying out , I could not open my sunroof fully and when the guys at tickover had her they fixed it ( only £40 ) and it's great driving around with the roof open my 10 year thinks it's great .
Jasonmarie wrote:Nice Top Tip there Nick and that shine on your car is 10 out if 10 .
Hey thanks Jason. Nice one fella :)
Got back from Brooklands Sun pm and decided to get it ready for another show down in Kent this Sat so it all ready to go. So had been meaning to treat the sunroof seal to try to restore it back to black. Had originally bought this gel stuff for another job but it seemed like it would do a good job on the seal too, which it did. Just use a tiny brush to apply it evenly and you should see a definate improvement.
Jasonmarie wrote:I could not open my sunroof fully and when the guys at tickover had her they fixed it ( only £40 ) and it's great driving around with the roof open my 10 year thinks it's great .
Great stuff mate. Does make a big difference when the roof is open...and it looks dam cool too :D
Only drawback is I need to be careful not to get sunburnt on my head :lol:
Even the underside of your garage roof is spotless Nick :)
pbar wrote:Even the underside of your garage roof is spotless Nick :)
:wave: :P
Hi Nick,
That's a great job, good work!
As you may or may not know, I highly rate Autoglym products. I do find with this bumper gel that although it does make rubber and plastic look superb, it does have to be reapplied quite regularly to maintain the appearance. Not a problem for you, I suspect...... :D
All the best,
Andrew 2.8i wrote:That's a great job, good work
Cheers Andrew ! Looks so much better than before :D
Andrew 2.8i wrote:although it does make rubber and plastic look superb, it does have to be reapplied quite regularly to maintain the appearance. Not a problem for you, I suspect...... :D
Yep am not expecting it to be a permanent finish mate but as I choose carefully when I bring B112 out for a drive I am hoping it will last a while...but as you say it would really not be a problem for me to reapply it every so often :woot:
Arya2.0S
Car(s): ford capri 2.0 s
Post by Arya2.0S »
Looks the dogs! You mentioned you applied it to your spoiler, how exactly did you do that and what did it look like afterwards? Got any pics?
Ive tried dying mine, but even that hasn't lasted more than a couple of months and now the spoiler looks naff again. I heard someone used wet and dry sand paper on theirs once and then treated it with something, every heard of doing that? Cant see it myself, the spoiler is made of a sponge like material.
Arya2.0S wrote:Looks the dogs! You mentioned you applied it to your spoiler, how exactly did you do that and what did it look like afterwards?
Here is a pic I took of the Capri just before setting off for Brooklands on Sunday. You might be able to make out the rear spoiler. Looks ok. Better than before.
Image20170521_051049 by nicholas bowler, on Flickr
I only had time to give it one treatment but I reckon a second would make it even blacker. I applied it with an Autoglym Professional Applicator which is basically a fancy sponge mate. It goes on very easy but obviously will not 'repair' any bad spots. Mine is not perfect at all and still shows the imperfections but it definitely improved the 'faded look' and now look blacker. Just be careful not to over apply it !
Another trick believe it or not is to use Peanut Butter, but only the 'smooth' one. There are oils in smooth peanut butter that do amazing things to rubber type trims, but its not permanent and will need reapplying. Plus it smells of peanut so might attract some wasps :lol: I tried it on my previous Laser's rear spoiler and was shocked how it works !!
PS In had not treated the sunroof seal or tyres when I took this pic. They both look much blacker now ready for a show I am going to on Sat down in Kent :x
Post by Caprigear »
Without sounding too kinky have you tried baby oil on the black trims? works a treat!
Caprigear wrote:Without sounding too kinky have you tried baby oil on the black trims? works a treat!
Ive got plenty of that, I'll give it a go! ;) :lol:
Arya2.0S
Post by Arya2.0S »
Yeah me too will give that a try.
Thanks too, Nick for the info.
Hi Martin. No mate have not tried baby oil yet. Ermm dont think I got any on my garage shelf...got loads of vasiline though :wave:
Seriously I may well give it a go if my trims start fading again. They dont look too bad after the autoglym. Thanks for the tip mate.
I've experimented too with that in the past. As you say Nick, has to be the smooth type. Only temporary though as most of these treatments are. WD-40 also makes most everything look great.
pbar wrote:WD-40 also makes most everything look great.
Paul I would rather eat WD40 than Peanut Butter mate :lol:
And just think how free and easy all of your joints would be!
Arya2.0S
Post by Arya2.0S »
Same. Peanut butter is vile.
