Saving the 2.0s
- Car(s): Ford Capri 2.0s, Glacia blue.
Saving the 2.0s
Hi, im George, 22 from west Essex, i have recently bought my first and hopefully only Capri which is a mk3 2.0s in glacia blue.
I have always wanted a Capri and finally have one, my aim was to buy one that needed to be saved as my intention was to stop another Capri from dying!
I found this 2.0s locked up in a shed in need of restoration, the last time it was taxed and MOT'd was 2007.
The aim is to have it as a usable restoration, to restore it to a high standard as well as driving it while i do that to enjoy the car for what its made for (going sideways)!
If you are all interested, follow the topic and hopefully we can all build this together, i can use others advice and knowledge to overcome the issues i may have.
This car will be ready to show by spring next year 2017 (paint bubbles or no paint bubbles).
When i bought the car the valve stem seals had gone and the cam lobes had bridged out, very very smokey (ill post a picture when i work out how to).
the roof had the usual rust around the sunroof, terrible passenger foot well repair fell out, exhaust was blowing, fuel tank was full of off fuel, usual leaky diff seal, bumpers were dented in, and the worst of all being the filler repairs in various places around the body (rear valance, below headlights, bottom of door skins, top corner of wings).
Lets see what we can achieve, thanks
George
George
Re: Saving the 2.0s
to the Forum George. Looking forward to seeing some photo's of your car and how you progress with it
Neil
Neil
Re: Saving the 2.0s
Thanks Neil, i have a holes in my pockets, wallet and bank card, but as every build is, time and money is against me, ill do what i cansheff wrote: to the Forum George. Looking forward to seeing some photo's of your car and how you progress with it
Neil
George
Re: Saving the 2.0s
This is the first photo i took when we dragged her out the shed, looks in better condition here which is why i like the photo
Re: Saving the 2.0s
The Horrific repair that was done previously, luckily it was red oxided around the plate to stop further rusting
Re: Saving the 2.0s
The condition of the roof around the sunroof. Typical perished seal allowing for water to sit behind the raised sunroof!
Re: Saving the 2.0s
Starting the engine up, the bridged out cam lobes providing a show for the neighbours
Re: Saving the 2.0s
I am going for a look that i like despite what others think, light mod of removing bumpers as personal preference
Re: Saving the 2.0s
Nice I'm a big fan of the 2.0S model and this one is a nice colour.... I can see in the other photo's you have a fair amount of rust, but this can be fixed and you will have a great car when finished.
Re: Saving the 2.0s
The front surrounds and grille were slightly faded, and grille was cracked.
after a glue repair, 800 grit rub down with wet and dry, and added plasticizer into the 2k primer and top coat, the front is now restored to satin black (new badge needed so if anyone could guide me to one at correct size please)
Re: Saving the 2.0s
I like Capri's with the bumpers removed. If you're not worried about keeping it looking original then removing the bumpers gives it a different look. You can always refit them if you change your mindCapri&Corona wrote:I am going for a look that i like despite what others think, light mod of removing bumpers as personal preference
Re: Saving the 2.0s
Due to the cam being scrapped, i have rebuilt a new gt injection head, ported using steel carbide burrs and emery cloth, skimmed (professional done as lack of equipment), 2.0 kent cam, unleaded valve seats, new valve springs, recon/measured valves, seat guides, valve seals, now running short plugs, recon 38 downdraught set up for 2.0 fast road, new K&N filter, Ashley exhaust system including manifold, new water pump, new belts, recon pump pulley, new viscous unit, and freshly painted fan to match the samco hose kit. photo was from mid build, will upload more soon.
starting to run low on cash wishing i can print it! the beast is booked in for welding next week to do many repairs as far as my budget can take me including a fresh coat of paint on the exterior only as a previous bad respray caused flaky paint on my drive.
Re: Saving the 2.0s
Thanks i was always looking for one in white, being from Essex i thought lets keep it looking as Essex as possible, seeing the light glacia blue is also a bit flash, also being a rarer colour, ill keep with that and see what i can do.sheff wrote:Capri&Corona wrote:
As for the rust, i am getting a professional to do cover that and thats where the funds are going as everything else i can pretty much do myself
Thanks for the interest, pass it on.
George
Re: Saving the 2.0s
Hello and
Good find and an 'S' of any sort gets my vote.
Car looks a good base to start a resto, and you will find alot of helpful/ knowledgeable people on here (Not me though)
and Capri Gear (Martin) is a good source for spares.
Look forward seeing your progress and you should make the car you like, although still being able to return it to standard if needed IMO
'Simply Ford' at Beaulieu is usually early May so if you could make that Keep an eye on the Rant and Rave Section for info in the new year.
Andy
Andy
Re: Saving the 2.0s
Hi Andy, thanks for your interest and your advice its a great help, im sure ill be in contact with martin for spares pretty soonish.andyd wrote:Hello and
Andy
yes the idea is to modify the car to my preferance, however all mods can be quickly turned around back to standard condition for re sale (if i sell)!
im definately interested in making most of the events next year as close to south as possible to enjoy the social side of things. Ill keep everyone updated on the progress as soon as i can!
Thanks, George
Re: Saving the 2.0s
The car is set to be delivered to the fabricators on 1st October! Its in for floor repair, roof repair, rear arches, rear valence, drivers sill, passenger A post, front valance, rust removal on inner headlight bowls, rust removal on spare wheel well, front wings scabby at the top will be sorted, rear wing (duck tail) fab and alignment, and to top it off, full exterior respray including engine bay!
Re: Saving the 2.0s
Hi George,
Welcome to the forum!
Your car looks like a decent starting place for a restoration, and the S models are definitely worth saving if possible.
Good luck and keep us up to date with the work as it progresses.
All the best,
All the best,
Re: Saving the 2.0s
Thanks for your interest Andrew, ill keep everyone updated as much as possibleAndrew 2.8i wrote:Hi George,
All the best,
- Car(s): Car
Re: Saving the 2.0s
Welcome mate. Car looks a great project and in a rare colour. Good luck with the resto, will be a nice car to save.
Re: Saving the 2.0s
Great looking Capri S & a nice colour. It's good that you plan to save it as there aren't many around, keep us up to date on your progress, owned one myself & loved it.
