Can anyone advise where I can pickup a set of piston rings for my EFI pinto. It came from a 1988 Ford Granada Ghia I,
I've found piston rings for the none injection models. Or piston rings for Injection but +Size
I'm after standard size injection pi to rings, cheers
pinto Piston rings where to buy?
- cabaret
- Car(s): Ford Capri 2.0i
Skoda Fabia 1.9 SDI - Location: Wolverhampton
I am the Nightrider. I'm a fuel injected suicide machine. I am the chosen one The mighty hand of vengeance sent down to strike the unroadworthy! Im hotter than a rollin dice. Step right up, chum and watch the kid lay down the rubber road, ride to freedom!
Re: pinto Piston rings where to buy?
Wouldn`t the rings be the same for an efi as a carbed engine?
- Car(s): Y reg 1.6L in imperial red, ex owner of 3.0s and 2.0 GL in gorgeous Tibetan gold
What size do you need? I have a few sets on my shelf.
- cabaret
No apparently not, when I've been looking it says not for injection! You need the later piston rings for the injection models apparently. And theyare the one ones iI'm struggling to find. I'll measure the size and get back to Tamworth!
They are different it's down to a different ring diameter,
Mahle do them
http://mattlewismotorsportonline.com/fo ... 1726-p.asp
Mahle do them
It`s the thickness of the top ring, earlier ones were (I think) 2.0mm, later 1.6mm - but this also applies to the whole range of Sierra Pintos, including the 1.6L from a certain date. I`m still not sure it`s specific to efi, they ALL had thinner rings after that time? As long as they`re correct for the piston they`ll be OK. You need to measure the thickness of the top groove/top ring in existing items.
- cabaret
Thanks for the heads up guys. I will measure mine and then get the correct ones. Cheers!
