V8 32V Zakspeed
Hot_Protein
Re: V8 32V X Pack
Post by Hot_Protein »
MinesGT wrote:Hi
Its still on going!! Unfortunately work got in the way big time, so progress has been very slow.
Transmission tunnel is all but finished, along with gearbox mountings. Engine and box are both now mounted in place, and currently playing around with the ride height/suspension geometry.
Now going coilover etc at the rear, and once setup, will be making custom steel arches (hopefully!) to suit the wheels/ride height.
Will post up more pics when I can find em :)
Ahh, interesting. So you're not going the X-Pack route any more then. I'm going to need to modify an X-Pack kit to fit what I plan to do. Steel would be nice. I have considered it but I know it's out of my skill range (cardboard and sticky tape) so I won't attempt it without precedence. Maybe you could do a tutorial during the construction of your arches. If you're feeling generous.
This build is awesome so far. I hope you get more time to finish.
MinesGT
Car(s): 2008 Bullit Mustang, Capri 32V V8 X Pack
Re: V8 32V X Pack 4 Years On !!
Post by MinesGT »
Can't believe its been on the go for that long.........
To cut a VERY long story short, after a lot of changes (moving premises twice!!, and withdrawing from another business), I have managed to get my enthusiasm back, and start spending some time back on the Capri.
I lifted the engine up a touch, and changed the cross member to a 2.0, so I could use the manual rack.
This meant I needed to repair the gearbox tunnel again, and fabricate/move the gearbox mounting brackets. I used the bottom half of the existing brackets, and fabricated a new top piece, to fit the repaired tunnel.
Marking out first.
Support plates were tacked to hold both parts together prior to welding.
I then spot welded some strengthening plate.
The bracket was then self tapped then tacked and welded into position.
More updates later this week!!
BMWcapri
Car(s): BMW V8 powered '81 Calypso
Post by BMWcapri »
glad to see this is still happening,
I found parking a bit of a work-out with the standard 2L manual rack & a 200kg motor, but then there wasn't room for a P/S rack in mine.
keep up the good work!
MinesGT
Post by MinesGT »
BMWcapri wrote:glad to see this is still happening,
Cheers. Going for an electric column, hopefully.....
MinesGT
Post by MinesGT »
Tried going with a more factory look to the gearbox bracket. Originally for a Mustang, it would not allow the gearbox to sit high enough, so made a support brace first to support the gearbox, then cut down the bracket.
Then bolted the mounting faces, and bolted then to the body gearbox brackets.
Once bolted in place, it was a case of bridging the gaps to form the complete bracket.
Then grind back the welds, and a spot of zinc primer
More updates next week, hopefully!!
MinesGT
Post by MinesGT »
With the gearbox in for the umpteenth time, its time to start fettling the transmission tunnel....
Its a bit tight with the heater box, but hopefully should go back in...............
Still a bit of trimming on the tunnel to do, but once the ride height has finally been set, and rear axle clearance set, the I can stitch everything up between tunnel/prop/ rear tunnel.
Matty28i
Car(s): Mk3 2.8i not a 2.8i any more... 2.9 24V BOB Long Term Project.
Post by Matty28i »
MinesGT wrote:With the gearbox in for the umpteenth time, its time to start fettling the transmission tunnel....
Hi Kev,
Good to see you are getting back on this project. 4 years? You sure it's not a bit more? :poke:
LOL
Matty
MinesGT
Post by MinesGT »
Errr well might be a little bit longer......since 1993? :)
How are you keeping? Everything ok?
MinesGT
Post by MinesGT »
Just leaving the tunnel loose for now until I have set the ride height,just in case I need to alter the floor/chassis at the rear, then I can tie it all in together.
Well that's the plan anyway!!
In the mean time, I have made some adjustable "rear coilovers". Well its a bit of box section, drilled with some threaded bar, and nuts!!
It is a bit crude, but helps setting the rear ride height, without resorting to trial and error with lowering blocks etc. I have removed the rear shockers, and replaced them with the box section/threaded bar. All i need to do is tighten / slacken the top nut to achieve the desired height.
Once I am happy, then I can get the rear coilovers made up to the correct length.
Its only cost £12 for materials, but at least gives you a chance to play around a bit :)/>
Getting somewhere near for the height, but need correct overall diameter tyre to be sure.
MinesGT
Post by MinesGT »
Needed to get some wheels which were much nearer to what I needed. Could'nt wait for 17's for mock up, so went with 15's, and changed the size/profile of the tyre to compensate.Might need to go a little wider at the rear......
Nice to get it on 4 wheels again (even if only temporary), make sure i have not "overdone" the lowering....
Could'nt help fitting the doors, and wing........
Just trimmed enough off the wing so it would clear the wheels
Starting to look more like a car. Not going X pack anymore (anyone know how to change the title of the thread?). Just taped some Zakspeed arches on for effect, but will be looking to do something similar in steel, with a different front spoiler.
A quick photoshop of the wheels
Craigorypeck
Chevy Cobalt
Post by Craigorypeck »
Very nice. Lots of good work going on there.
To edit the title edit your first post.
:spam:
It looks amazing! But the ultimate choice of wheels don't suit it at all in my humble onion :?
MinesGT
Post by MinesGT »
Craigorypeck wrote:Very nice. Lots of good work going on there.
Cheers!!
MinesGT
Post by MinesGT »
Major_Tom wrote:It looks amazing! But the ultimate choice of wheels don't suit it at all in my humble onion :?
Wheels are a bit blingy to be honest (and may need more dish, and darker paint), but I'm not the best photoshopper to be honest, lol
Give it another 6 months, and I will have probably changed them again....
BMWcapri
Re: V8 32V Zakspeed
Post by BMWcapri »
great project, any updates?
Will01
Alfa 156 GTA (Daily Driver)
Alfa 2.4JTD Sportwagon
Mini Cooper S (Wife's)
Old Jags & Riley's for fun
Re: V8 32V Zakspeed
Post by Will01 »
Looking low. That is defo something i need to get round to sorting and having a look at!
Not a fan of the wheel choice haha, but the Zakspped arches look good
Will01
Re: V8 32V Zakspeed
Post by Will01 »
Any updates?
MinesGT
Re: V8 32V Zakspeed
Post by MinesGT »
Very Spooky !
I got back on this just last week. Got a bit side tracked with another project (Ranchero)
I needed to re think the front suspension geometry ets, with having it so low, but starting to get round it now (possibly shorter strut inserts), along with maybe cranked steering arms/ re drilling crossmember, lifting engine a little etc.
I might get this finished before I am 60........
Will01
Re: V8 32V Zakspeed
Post by Will01 »
Ranchero cool
