1.6L restoration
tejb1
W- Mondeo 2.0 Ghia Estate
03 Focus 1.6
1.6L restoration
Post by tejb1 »
I've been reasonably quiet recently and you'll have noticed no updates on my Capri.
Last summer, I decided that as autumn approached, it was time for her to come off the road and receive attention to a number of areas bodywork-wise.
The only thing to do was to bite the bullet and get everything done properly.
Although the car still looked good, there were a number of areas which really did need addressing. This section had been shovelled with filler in the past.
The local garage had a welder who was going to do the work, so I started the slow process of stripping everything off the car.
The interior was quickly out and stored in my flat for safekeeping.
The dash came out, bit by bit, part of me thinks this will be a right pain to put back together although I have tried to take lots of notes and pictures. By the time it goes back in it'll be pushing on a year so hopefully I don't lose anything!
With the carpet and underlay up, it was time to do some 'corrosion assessment' with the aid of a screwdriver...
Hrmmm! As I suspected, the more that I dug, the more work became apparent.
Off with everything that'd come off the front....
Everything that came off, I packed into boxes with protection, labelled them all. I hope this is going to make my life easier when it all goes back together, since things should be in a logical order (in saying that, I know of several things which really aren't).
The doors came off to see what it was like behind. Here's a tip. If taking them off or putting them back on, don't be a stubborn prat and try to do it yourself, my back didn't forgive me for a long time!
Also out was the heater matrix / blower box. I ended up giving this a flush through in the bathroom at home, it's clean and clear which is good.
The car was ready for a professional to start work on it. There had been a delay as the original bodyworker had moved on, but the day came and she was out in the sunlight...
On to the transporter it went....
Whilst the car was away, it was time for me to do a few little bits and pieces - brackets and so on which had come off the car were cleaned up, de-rusted and painted.
in the background you can see the little rotary tool. This was about £15 off Amazon and has been an absolute dream, USB rechargable, and gets into all sorts of small places. a cheap version of a dremel and no, for the price it isn't going to last forever, but it's coped happily with all sorts!
I got regular updates from the welder and popped to see the car mid-way.
Here's just a few photos of what was found and sorted out. Both wings came off and had work underneath, scuttle and A posts, fronts of the sills, headlamp bucket, valance, rear quarter, and probably more that I've forgotten off the top of my head. There was more work than anticipated and it cost more than planned but as the work was underway better to get it all done and dusted now (and get the overtime forms out).
8 weeks later and the car was back, now solid.
I'd not intended on getting a respray done either, but came around to the fact that it was necessary.
While waiting for the painter to have a free slot, I decided to check and clean the rear washer jet which hadn't been working in all the time I'd had the car. Time to get some of that famous de-clogging solution of, err, cola!
(it worked to some extent but pressure still very poor, although absolutely fine when the jet itself is disconnected. Hrum. Replacement jets in the region of £60 on ebay which is a bit much on a whim. I'll see if Martin or anyone has them).
Another job is replacing the fuel lines, including the rubber bit at the back off the sender, and the nylon that runs all the way down. Now the nylon shouldn't degrade at all, in fact when I took the old stuff off I sliced through some of it and it looked in perfect nick, just covered on the outside with crap and underseal.
While the car was being worked on, one of the rear shackles had sheared off. Little did I know what a pig of a job this was going to be!!! First battle was to actually get the old ones out!
A replacement set procured...
In the photo above you can see that the metal sleeve has become seized to the old shackle, so I needed to get replacement sleeves.
These are a very tight fit and very difficult to get in, especially on your back, underneath the car, in the end I assembled a long bolt, nut, and a couple of washers to 'wind' them in slowly, once this was started it was slow but smooth progress, see next pictures...
And with that the shackle was back on and secured. Phew! Although you're not supposed to tighten them too much I do always get a bit paranoid with these. The nylocks went flying across the garage at some point so I've a normal nut on them but will replace before it goes on the road.
And that's the car as it currently stands, waiting to be repainted...
Once the paint is done it's just(!) then a matter of refitting everything (including glass), reinstating the dash, interior, all the bits under the bonnet I took off for better access - we have approx 107 steps on my reassembly to-do list!!
Re: 1.6L restoration
Nice post, I enjoyed looking/reading through that.
Looks great Tom, fair play for getting stuck in!
SCP440
Post by SCP440 »
Nice to see what has been done, I suggest a good dose of cavity rust protection once the paint has been applied. Dont be tempted to do it before hand as a lot of these products contain silicones.
The other thing I suggest is every bolt and nut gets a dose of Copper grease on the threads and contact areas and I dont mean the rubbish that Halfords sell.
tejb1
03 Focus 1.6
Post by tejb1 »
SCP440 wrote: Wed Jul 26, 2023 7:05 pm Nice to see what has been done, I suggest a good dose of cavity rust protection once the paint has been applied. Dont be tempted to do it before hand as a lot of these products contain silicones.
Once it has been painted then yes for sure, I don't want to have to go through it again!
Yes, wherever possible I have used brand new fixings, everything has been greased to hopefully avoid issues next time something has to come off.
Caprigear
Post by Caprigear »
The shackle is upside down.
tejb1
03 Focus 1.6
Post by tejb1 »
Caprigear wrote: Wed Jul 26, 2023 10:37 pm The shackle is upside down.
Thanks Martin. I'll rectify it once the car comes back.
Looks great, love the old Nissan too, is it a Bluebird?
tejb1
03 Focus 1.6
Post by tejb1 »
Major_Tom wrote: Thu Jul 27, 2023 12:28 pm Looks great, love the old Nissan too, is it a Bluebird?
Yes, that was my daily for a few years, but unfortunately it was a casualty of ULEZ.
Nice one Tom , you have worked hard and she will be back to her glory soon :cool:
Hi Tom, I didn't even realise your car needed so much work. It looked great the last time I saw you and it. (Brooklands?)
tejb1
03 Focus 1.6
Post by tejb1 »
Hi Paul - yes, it probably would have been Brooklands.
There were a number of elements of corrosion which needed addressing permanently, which had been kept at bay with kurust and underseal, a couple of MoT plates in recent years, plus there were a lot of suspicious bits which I knew were filler. And one thing lead to another...
Hey Tom. Fantastic thread mate. Just noticed it. Brilliant work done. 590 is gonna look stunning. Nice one mate. Keep up the great work.!!
Stish704
Vauxhall Mokka. The wife’s!
Post by Stish704 »
I’m impressed Tom, looking great! To be honest, scares the crap out of me doing all that. In case I lose anything, break anything or damage anything as I am pretty heavy handed.
Can’t wait to see it again. And you of course!
tejb1
03 Focus 1.6
Post by tejb1 »
Stish704 wrote: Tue Aug 15, 2023 6:19 am I’m impressed Tom, looking great! To be honest, scares the crap out of me doing all that. In case I lose anything, break anything or damage anything as I am pretty heavy handed.
I'll let you into a secret. Scares the crap out of me, too! And I haven't even done any of the actual serious stuff!
The disassembly took place over about 4 months last autumn, and my garage now has lots of labelled boxes. But you're right, it's a bit frightening thinking "will it all go back together?!". However, even although there might (no what do you mean - WILL!!) be challenges along the way, one day I'll be driving along in it and feeling on top of the world for having dealt with it.
tejb1
03 Focus 1.6
Post by tejb1 »
Right, where are we. Progress - slow.
I took the starter motor off and to the local refurb company in Borehamwood (Unit Exchange). Although it worked fine I thought it sensible to have it refurbished whilst I was doing everything else, some bearings were a little rough so were replaced and a full recon done. (they usually turn this sort of thing around in 24hrs, but had to wait a little while for some apparently more obscure parts to arrive).
Next up, fuel tank replacement. The old one had been run very low, but I drained the fuel off into a jerry can, chucked that into the modern car, repeated that a few times - just over 2.5 gallons left in there I think.
Removing the sender was a pain but I found that the three-pronged oil filter ratchet was perfect for getting it off without the risk of damage that you get if using a long screwdriver?
The old tank had surface rust but was (and is) in ok condition with no leaks. The rationale for replacing it was that, since I was doing so much work, I would rather change out other things at the same time whilst the car was off the road.
If anybody could make use of a rusty but ok tank I'd be happy for a genuine owner to have it foc - might get somebody out of a corner. It seems silly to throw it away, but you can't keep everything...
Underneath the spare wheel there was some further surface rust which was ground back, kurusted, primed and topcoated. This was a rattle can job so won't look beautiful, but it is out of sight.
New tank was fitted with the ancillaries
Interior of the old tank, looks almost fine.
New tank was then fitted, it was a reasonably straightforward job in all fairness, although the fitting-refitting would have been a lot easier with another pair of hands. The use of a jack was absolutely invaluable!
The new tank was filled with a couple of gallons of unleaded and everything started up fine. I've tried to keep the car moving up and down the drive and around the yard, rather than let it sit.
Repaint wise, I've been waiting for quite a long time now, but on speaking to other firms they are also backed up - I suppose if you want a job doing properly you have to wait for the right guy to do it.
And a reminder photo of shinier times, which will return! here refitting an alternator outside Jon's...
Looking good Tom!
Will definitely be worth it once it's all done 👍
Fitting the tank is definitely a two man job isn't it?? Had the same issue when my straps broke, using a jack is the only way I managed it!!
Looking great Tom , you really have been busy . So will you drive her in the rain now when done ?
