Hardened Valve seats
Rosco59
Car(s): Ford Capri 2.0s Restoration project
Post by Rosco59 »
Hi does anyone know where you can buy hardened valve seats. It's for a pinto with standard valves. Thanks
Re: Hardened Valve seats
I would think the automotive engineer you will need to do the required machining would supply them .🙂
I don't know where you are based, but as Hamish says take your cylinder head off and take it to an automotive engineering works. The old valve seats have to be machined out and the new seats are a hardened steel which frozen in liquid nitrogen then dropped into the machined out "hole". When it all gets to normal temperature it forms an interference fit to keep the new seats in place.
It most definitely is not an "at home " DIY job.
Just thinkin a bit more . If your car has a few miles on it .......like maybe needs valve guides lookin at , it might be better to buy a whole head , specially if you can exchange the old one . Maybe someone like Burton power .🙂
Rosco59
Post by Rosco59 »
Hi I work in a machine shop and was going to try it on a spare head but couldn't find anywhere to buy the valve seats. Thanks
Burton power do sell hardened valve inserts ( I saw them whilst searching their cylinder heads )😁
