I have just removed a complete system for the 260 brake mods from my car.
They were fitted about 6 years ago and were never used apart from road testing.
Sierra xr4i calipers rebuilt with new seals, painted,they have surface rusted a little bit.
Mounting bracket for caliper bracket, with s/s hydraulic hose and new pads.
Machined hubs, long wheel studs and Escort rs260 discs, (will be cleaned up)
BRACKET KIT £50
HUB MODS £25
HOSES £25
WHEEL STUDS(8) £10
DISCS/PADS £85
CALIPERS £70
Asking £145 + p&p (heavy) or collection Norfolk.
Capri 260 front brakes complete
- Car(s): Capri 2.8i restored.
- Goz
- Car(s): Ford Capri mk2 1600GL, BBC slingshot dragster build project. 1200 Bandit daily driver
Re: Capri 260 front brakes complete
will these brakes fit under 13" wheels?
does it change the wheel position/offset by much?
and do the struts require any modifications (drilling mountings etc) to fit?
i'm very interested, cheers Andy
Hello Andy,
Yes they fit in 13" wheels as they were on my 2.8i with pepperpots.
No i did not have to drill out the strut mountings holes, the bolts went through ok.
Mike.
Mike.
Sorry, the offset changes about 10mm wider.
Mike.
Mike.
Sorry, senior moment, the bolts for the caliper bracket use the existing holes on the struts to fix to.
- Goz
thanks for the replies, ive pm'd you
