Noise from exhaust
Jim
Car(s): 1.6
Noise from exhaust
Post by Jim »
The other issue I have had recently is a noise that I can only describe as a bong when the engine is idling and a tinny, rattling noise when the car is rev'd between approx. 2000 and 3000 revs. You can hear the bonging noise when you are away from the car quite clearly and is most prominent when you are under the car near the exhaust at the front.
Does anyone know what this could be?
Re: Noise from exhaust
I had a bong in my car too , the police are real good at finding them 😁.
I bought a ford escort that had a rattle from the exhaust ....turned out to be half a valve seat.
I guess the thing to do would be to make sure all the fasteners are tight and that the exhaust is not touching anywhere. Pushing something like a bit of wood against the exhaust ( as a dampener ) at various spots can help to locate the noise.
I have a car that the exhaust buzzes and rattles as it heats up but thats small stones in the heat shield , there could be a stone sitting on/in a bracket somewhere. Does the noise change as the car warms up ? Can you simulate it by tapping on the exhaust while car is not running ? And are you sure its the exhaust .....dont get tunnel vision coz it might not be the exhaust ........they are the usual culpret but you never know 😊
Jim
Car(s): 1.6
Post by Jim »
Thanks for your reply Mc Tool. I've had another listen and a feel whilst its running and it seems to becoming from the starter motor. Would make sense as I have had trouble with the starter motor recently where the car will make a conking noise but not start when turning the key. Should the starter motor be going though whilst the engine is running?
Jim
Car(s): 1.6
Post by Jim »
Took the starter motor off this morning and cleaned all the connectors. Didn't dismantle the starter motor but the teeth appeared ok. Refitted and the car fired up pretty quick but the rattling noise is still there. The bong noise has gone though. Almost sounds like something small rattling and ticking about in the bell housing.
STEVEW
Car(s): Ford Capri 2.3S
Project
Post by STEVEW »
Hi Jim,
You wrote,
Many years ago, I had a similar problem with a Ford F 250 (1970s vintage), which was caused by the clutch friction plate.
The " steel fingers" connecting the centre torsion spring holder to the friction discs had broken causing a rattling sound and in this case, no drive!
It's possible yours have started break.
You also wrote,
This could also be the cause of your noise.
The starter "dog" should be free enough to spin into the starter ring when you turn the key and also be free enough to return to its "parked position" when the engine is running. Over time they can attract gunge and goo which makes them sticky. In your case the rattling could be caused by the starter teeth tapping the starter ring whilst the engine is running.
As removing the starter is obviously easier than removing the gearbox that's where I would start.
All the best.
I wonder if the exhaust gasket is sealed ?
I've had a similar problem in the past and it was as Hamish has suggested - the exhaust was hitting something on the underside of the car, and exactly like he has suggested, if you pry the exhaust away at various points with a piece of wood I found where it was touching and moved it.
However, quite an odd thing to just start doing on it's own - Mine was just after I'd installed a new exhaust
The starter issues sound more like the culprit to me - have you tried the trusted method of twatting it with a hammer repeatedly until the car starts? my starter started doing exactly as you described a few years ago, twatted it repeatedly and the issue mysteriously vanished and has yet to rear it's head again!
Haydn Gnarlerboy on here (a few people will remember him) had an issue similar to what you describe here and it turned out to be exhaust baffles resonating in the silencers. That sounded like a hollow, metallic rattling at certain engine speeds.
Blowing exhaust gaskets sound more like flapping, popping, bursts of sound, progressively more loud and severe at higher revs.
No idea what the bonging could be though. Can you record it?
D366Y wrote: ↑Fri Jun 03, 2022 9:30 pm Mine was just after I'd installed a new exhaust
I can confirm that your exhaust makes a lot of noise ! :D :D :D
Jim
Car(s): 1.6
Post by Jim »
Thanks for the reply guys.
Had my MOT and the technician listened to it whilst it was in the air and it is definitely coming from the bellhousing. He pressed the clutch and it disappeared so he reckons it's the clutch release potentially not coming away enough when released so it's tapping on the clutch.
I listened to the noise whilst pressing the clutch while driving after the MOT but could still hear it so not 100% sure now. Will try adjusting the clutch to see if that makes a difference.
Post by Mr B »
Jim wrote: ↑Sat Jun 04, 2022 7:42 pm Thanks for the reply guys.
Could also be the clutch fork arm rattling around a bit, often found this to happen when the clutch cable has too much slack in it, do all the gears select easy and smooth?
Andrew 2.8i wrote: ↑Sat Jun 04, 2022 6:44 am
I'm quite sure I don't know what you mean.....
πŸ‘€
Jim
Car(s): 1.6
Post by Jim »
Hi guys, thought I would update you all.
Had someone else look at the car and they said take the starter off and take another look. It would appear that the bendix doesn't return when it is pulled out and it's loose on the shaft which I suspect is causing the rattling. Could this be caused by a failed solenoid or could it be something else in the starter?
Many thanks.
nemo
Car(s): none at the moment
Post by nemo »
IIRC there is a fairly strong spring inside the solenoid which pulls the pinion back on release. If that`s failed (how????) it would cause your symptoms.
Jim wrote: ↑Thu Sep 07, 2023 5:33 pm Hi guys, thought I would update you all.
Many thanks.
James
I've heard this rattle several times on 1.6 Pintos and rattles from the bellhousing/clutch area are often the flywheel bolts coming loose. I've honstly done this job several times over the years both on Cortinas and Capris.
nemo
Post by nemo »
Paul G wrote: ↑Sat Sep 09, 2023 12:58 pm rattles from the bellhousing/clutch area are often the flywheel bolts coming loose.
Worrying! How does that come about, poor rebuilds? Hopefully not from Cologne?
nemo wrote: ↑Sat Sep 09, 2023 5:15 pm
No, as far as I understand they just vibrate loose after several years of use.. Usually a drop of loctite and re torquing does the job, it's just a pita that you have to remove the box and the clutch to get to them. I will add that the majority I had to do were 4 speeds but it's not unheard of for 5 speeds to do it too - a chap on Capri Power had the same issue recently.
Jim
Car(s): 1.6
Post by Jim »
Paul G wrote: ↑Sat Sep 09, 2023 6:22 pm
Hi Paul,
Thanks for the response. Hope you are well.
I subsequently took the starter motor apart and it turns out that the lever had come off the shaft. I reconnected the lever (although I feel like something might be missing here based on the other motors I've seen stripped down as it doesn't seem to move the shaft very well) and the noise seems to have stopped now. Found some broken pieces of metal in there. Not sure where they have come from unless that was what the lever was connected to but it doesn't seem to be affecting the starting of the car. The flywheel bolts were my next port of call.
Image Image
