Wings
Re: Wings
It would be if the owner caught you trying it.
This is the parts for sale section
- Car(s): drive 73 yellow 1300 facelift with a 2000cc engine
and a 76 V W beetle - Location: Shrule Co Mayo, Ireland
Re: Wings
Good joke I am the owner and need to remove them in order to re fabricate round the head lights and check for other rust spots any ideas ???
Re: Wings
It depends, if you`ve worked in a bodyshop for 30 years it`s no problem: if you`ve never used an angle grinder it`s a massive problem.
This covers it, the mk1 will be basically the same.
https://www.dailymotion.com/video/x5tzclf
Re: Wings
The toughest part is trying to get pattern part wings to fit. Have you found a source ?
Re: Wings
Hope to take them off and send them to Steadspeed restoration in Scotland. Spoke to owner who will restore them
Re: Wings
It makes sense really, if you havethe skills (or know someone) as 95% of the panel is usually solid, it only needs very specific areas replacing. I`ve often thught it might be better to use parts of an aftermaret as repair plates for the original wing. Especially considering how hard it can be to get a proper fit.
Re: Wings
Completely agree with you Steve, as you know I've repaired a wing previously. It's just that it is nice to see a make do and mend repair approach, as opposed to I'll Just buy a new one, which is more the philosophy of this modern age with most things.
Good on you Michael, hope it works well for you.
