Front grill prob
stevesafan
Car(s): Just purchased a 1982 2.8 capri
But daily driver is a range rover
Front grill prob
Post by stevesafan » Sat Feb 20, 2021 4:09 pm
just bought 2.8 mk3 can someone please tell me why holes line up in top of grill
But about 30mm out on bottom fixings so it flaps around at mo thanks
Re: Front grill prob
Post by Peter-S » Sat Feb 20, 2021 4:38 pm
Is this a standard 2.8 grill?
340truck
Car(s): Rat - GONE
Post by 340truck » Mon Feb 22, 2021 5:49 pm
No it's a George Foreman grill
:xd: :xd: :xd: :xd: :xd:
:sorry:
Post by Mc Tool » Mon Feb 22, 2021 6:59 pm
:sorry:
Post by Bug » Tue Feb 23, 2021 8:21 am
A photo would help tbh, but as I recall, the Mk2 used different mounting points: I think they simply put plastic captive nuts into a folded up piece of the skin.
The Mk3 had two extra brackets welded on to mount the grille.
Now, from previous experience, many moons ago I bought a Hella grille that had square driving lights mounted within a custom grille. This screwed into the original top mounting points, but to make it fit the bottom I had to chisel off the original welded brackets so it would sit flat, then self-tapper down into the horizontal surface.
Worth looking to see if there's any signs of those brackets being removed? A lot of Capris had those custom grilles back in the day.
Or failing that, it may simply be that someone has previously had a Mk2 grille fitted, and moved the anchor nuts to suit that?
stevesafan
Post by stevesafan » Tue Feb 23, 2021 7:39 pm
Thanks bug no there are bottom lugs but about 30mm away each side I've made 2 brackets in black
look OK thanks
