Electric Cut Off Tools
Anyone know why electric cut off tools are so hard to get in the UK? In America it's a common thing, but over here you can get air powered ones but it's hard to find as electric. Just seems so strange.
Re: Electric Cut Off Tools
4" angle grinder with cut off disc , 4" are good coz you can get 1mm thick discs and they are dirt cheap.....the grinder and the discs . I have 4 of them ,one each with cut off disc , ordinary disc , flap disc and wire knot brush . I got so sick of changing discs back and forth as I went thru various stages of manufacture /preparation I got a whole set
With angle grinders though, don't you find that they are just too brutal/meaty to get into the more delicate/smaller areas? Which is where a cut off tool would be great. Pity they are so hard to find though.
Paul,
I did see a Draper hand opera ted thing which `might` be OK: grinder for big bits, that for detail?? I know what you mean about grinders, you`r e limited to straightish lines and the radius means it`s difficult in corners.
This: https://www.amazon.co.uk/Draper-Expert- ... 046&sr=8-1
Yes I can see how a hand tool like that could be very useful. You can get mini (3") angle grinders, again they are uncommon though. The advantage of a cut off tool over an angle grinder is the position of the blade too.
People tend to buy an American one and run it through an inverter. Bizarre how the UK doesn't have them.
Was thinking of a dremel type of tool, but wonder if they are viable for cutting metal/panels, etc.
A dremel will do it I suppose, might be a bit slow? Never used it for that myself, but I`ve got a Li cordless one and TBH it`s not that powerful. Maybe someone`s done it? (When you say inverter, I assumed you meant a step down transformer 240 - 110?. Inverters convert DC to AC. or IS that what they do, run off a battery?)
Sorry, yes transformer, to enable 110v tools to run in the UK. Although I've just thought, it could be run direct off a generator I guess, as most have a 110v option also, for safety if the generator is used on sites with trade tools, etc.stevemarl wrote: ↑Sun Nov 08, 2020 12:39 pm A dremel will do it I suppose, might be a bit slow? Never used it for that myself, but I`ve got a Li cordless one and TBH it`s not that powerful. Maybe someone`s done it? (When you say inverter, I assumed you meant a step down transformer 240 - 110?. Inverters convert DC to AC. or IS that what they do, run off a battery?)
Never occurred to me but yes, of course, you`ll have a 110v on your generator! So does that make it an option??pbar wrote: ↑Sun Nov 08, 2020 12:48 pmSorry, yes transformer, to enable 110v tools to run in the UK. Although I've just thought, it could be run direct off a generator I guess, as most have a 110v option also, for safety if the generator is used on sites with trade tools, etc.stevemarl wrote: ↑Sun Nov 08, 2020 12:39 pm A dremel will do it I suppose, might be a bit slow? Never used it for that myself, but I`ve got a Li cordless one and TBH it`s not that powerful. Maybe someone`s done it? (When you say inverter, I assumed you meant a step down transformer 240 - 110?. Inverters convert DC to AC. or IS that what they do, run off a battery?)
stevemarl wrote: ↑Sun Nov 08, 2020 1:01 pmNever occurred to me but yes, of course, you`ll have a 110v on your generator! So does that make it an option??pbar wrote: ↑Sun Nov 08, 2020 12:48 pmSorry, yes transformer, to enable 110v tools to run in the UK. Although I've just thought, it could be run direct off a generator I guess, as most have a 110v option also, for safety if the generator is used on sites with trade tools, etc.stevemarl wrote: ↑Sun Nov 08, 2020 12:39 pm A dremel will do it I suppose, might be a bit slow? Never used it for that myself, but I`ve got a Li cordless one and TBH it`s not that powerful. Maybe someone`s done it? (When you say inverter, I assumed you meant a step down transformer 240 - 110?. Inverters convert DC to AC. or IS that what they do, run off a battery?)
Well, I guess I can just buy an American cut off tool and use it with a generator, preferable to buying a UK one and running off a compressor, an electric one would be more versatile obviously.
Can't help but wonder what everyone else uses though?
IIRC Edd had a plasma cutter, shame you can`t hire them? Or can you? you could probably get all the cutting done in a day or 2.
edit: just had a quick look and HSS do hire them out, there`s one in Trafford Park, there may be others more local to you? Might be worth researching?
(4 sentences and each one a question?)
I'm thinking more of tools to keep, future use, etc. Say, for example, you wanted to cut a 3" square out of the side of a door. Angle grinder is no use, too brutal, too bulky. So, what then? Old fashioned way of drilling holes in the corners and a hand blade? Or is there a tool we can have for such jobs.
Totally get that, you never know what you might need it for in the future: `better to have and don`t need than need and don`t have. How much are US ones?`
You can get them on ebay for around £40-£50 including overseas postage.
https://www.ebay.co.uk/itm/NEW-3-Electr ... Sw~uVfTm9Q
This looks really useful, mini grinder, only £27 including delivery, reviews on Amazon commenting how great it is for cars but looks very handy indeed -
https://www.amazon.co.uk/Katsu-Mini-Ang ... B00KDEVQQ0
The only difference between an angle grinder and the US cut off wheel is the angle bit . At 90deg I would think my grinder with a 1mm thick cut off disc would be more accessable than that above tool . 1mm discs are good because you get a thin cut line and because they remove less metal than normal 2-3mm discs they produce significantly less heat . For
building trailers ,panel steel and general light engineering I wouldnt be without one Dremmels are ok but the reinforced cut off discs are expensive and aint that robust , and you have the same issue in tight corners .
As for being brutal ,.... Oh yeah they can bite but its like everything else ,practice makes perfect . You dont get much more brutal than a chainsaw but skilled operators can do some pretty intricate carving with them. That wee angle grinder looks the bizz , its on the list
Well I can see it ,and the 1st thing I would do for cut off disc use , is to remove it or trim it down a bit (and the side handle if fitted ) otherwise they get in the way . Mmm cant say I've ever seen a 3" disc either .
