Alloy Wheels
- Car(s): Ford Capri 2.0 Laser (Daily Driver)
Alloy Wheels
Ummm anyone k ow what alloy wheels will fit my 1986 Ford Capri Mk3. As far as I'm aware everything is still standard on there.
How would I find out with all the offset, width, max size etc
Re: Alloy Wheels
Hi mate. Am guessing you're asking what wheels fit without any modifications. I got 7x15 4 spokes with 195 50 15 tyres and they fit fine... and thats with lowered ride height - 2" I wanna fit 205 tyres and been told these will be ok in my setup....Mrbaboon1985 wrote: ↑Thu Oct 29, 2020 9:30 pm Ummm anyone k ow what alloy wheels will fit my 1986 Ford Capri Mk3. As far as I'm aware everything is still standard on there.
Here's the spec on these from jbw.
https://www.johnbrownwheels.com/product ... 08-7015RS4
Re: Alloy Wheels
That's what I am indeed asking. Thanks for the quick replyFordoholic Nick wrote: ↑Thu Oct 29, 2020 9:49 pmHi mate. Am guessing you're asking what wheels fit without any modifications. I got 7x15 4 spokes with 195 50 15 tyres and they fit fine... and thats with lowered ride height - 2" I wanna fit 205 tyres and been told these will be ok in my setup....Mrbaboon1985 wrote: ↑Thu Oct 29, 2020 9:30 pm Ummm anyone k ow what alloy wheels will fit my 1986 Ford Capri Mk3. As far as I'm aware everything is still standard on there.
Re: Alloy Wheels
The Max size will depend on the offset really more than anything else - I have 7.5 inch wide on the laser with 205 tyres and never had an issue.
There's a website which I think is willtheyfit.com or something like that and you can put in the measurements of what you have currently and then what you want to fit and it will tell you the difference in height, width and depth so you know how much space you have to play with.
If you have the standard laser 4spokes they are only 6inches wide so you can definitely go bigger, up to 7 inches wide easily, up to 15inches diameter easily (same size as Nick has on his) any bigger than that will depend on the offset really... seen 16/17s on standard arches but not sure if the inner arches had to be modified to suit or not, don't see many with wheels that big!
Re: Alloy Wheels
7 x 15 will be sufficient. Now to hunt down some nice ones
Re: Alloy Wheels
I have spoken with this company, very helpful and good prices too https://www.randr-alloys.co.uk/
Not too many 15x7 options for the Capri but these are popular;
https://www.randr-alloys.co.uk/performa ... -7x15.html
https://www.randr-alloys.co.uk/classic- ... -7x15.html
Re: Alloy Wheels
If you've got the cash Compomotives look the nutsMrbaboon1985 wrote: ↑Fri Oct 30, 2020 7:56 am 7 x 15 will be sufficient. Now to hunt down some nice ones
Re: Alloy Wheels
Re: Alloy Wheels
Re: Alloy Wheels
Jason ( "Jasonmarie" .) from on here has fitted these wooden beauties to his Capri but he says they are very noisy. He has to treat them with a wood preserve once a year so factor this cost in.....
Re: Alloy Wheels
I do get a wheel wobble at 30 mph with theseFordoholic Nick wrote: ↑Fri Oct 30, 2020 10:57 am Jason ( "Jasonmarie" .) from on here has fitted these wooden beauties to his Capri but he says they are very noisy. He has to treat them with a wood preserve once a year so factor this cost in.....
Re: Alloy Wheels
You're obviously part of a splinter group?Jasonmarie wrote: ↑Fri Oct 30, 2020 11:58 amI do get a wheel wobble at 30 mph with theseFordoholic Nick wrote: ↑Fri Oct 30, 2020 10:57 am Jason ( "Jasonmarie" .) from on here has fitted these wooden beauties to his Capri but he says they are very noisy. He has to treat them with a wood preserve once a year so factor this cost in.....
Re: Alloy Wheels
looks like I SPOKE too soonBug wrote: ↑Fri Oct 30, 2020 1:15 pmYou're obviously part of a splinter group?Jasonmarie wrote: ↑Fri Oct 30, 2020 11:58 amI do get a wheel wobble at 30 mph with theseFordoholic Nick wrote: ↑Fri Oct 30, 2020 10:57 am Jason ( "Jasonmarie" .) from on here has fitted these wooden beauties to his Capri but he says they are very noisy. He has to treat them with a wood preserve once a year so factor this cost in.....
Re: Alloy Wheels
CCI 280 copies but not cheap at £880 inc postage for 4 wheels https://www.ebay.co.uk/itm/Ford-Capri-2 ... SwKPNTyOlQ
Re: Alloy Wheels
So the new alloys are on... The tyre fitters think I need longer bolts..... Is that easy to do and where can I get some...
Re: Alloy Wheels
easy enough to change - wheels off, hub off, gently prise (with a large hammer) the old studs out, then gently (again, twat with a hammer) the new ones in the back of the hub.Mrbaboon1985 wrote: ↑Thu Nov 05, 2020 10:40 am So the new alloys are on... The tyre fitters think I need longer bolts..... Is that easy to do and where can I get some...
Not sure where to purchase them from mind as never changed them
Re: Alloy Wheels
The studs are splined and pull in tight to the hubs. You can of course 'twat them with a hammer' but another method which also works is to use a wheel nut to pull them on.D366Y wrote: ↑Thu Nov 05, 2020 1:12 pmeasy enough to change - wheels off, hub off, gently prise (with a large hammer) the old studs out, then gently (again, twat with a hammer) the new ones in the back of the hub.Mrbaboon1985 wrote: ↑Thu Nov 05, 2020 10:40 am So the new alloys are on... The tyre fitters think I need longer bolts..... Is that easy to do and where can I get some...
If your wheel nuts have enclosed ends they won't go tight enough, but you can pack out the stud with washers, or a socket, or use an old standard wheel nut.
I assume as you've got as far as fitting them that the nuts are the correct shape to snugly fit the holes in the wheel? Some are chamfered and others are flat, and they should have a captive washer that is free to rotate, so the nut doesn't cut into the alloy.
Re: Alloy Wheels
There on just the tyre place think longer studs would be better to secure them!
Re: Alloy Wheels
I think I heard somewhere once that it's recommended to have 7turns on the nut or something? If that's correct and you have that many turns I'd leave it as is?Mrbaboon1985 wrote: ↑Thu Nov 05, 2020 1:34 pm There on just the tyre place think longer studs would be better to secure them!
Re: Alloy Wheels
Caprisport are selling longer studs in pairs for £4.69 on Ebay.
